Super high idle when cold? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 02-01-2013, 06:34 AM Thread Starter
scummins's Avatar
Remote started my truck this morning, walked down stairs and fed my cat, came back up and could hear my truck idling really loud and there was white smoke everywhere. I killed the engine via remote, finished getting ready and went back out with the key and restarted the truck. It was still idling high at around 1100-1200 rpm. I was freaking, thinking it had something to do with the update I did to my mini maxx yesterday. Put it in drive and it dropped to 700-800. Drove to work and it was back to 600 rpm at idle.
Is this normal for super cold temps? This is the coldest morning that I have owned the truck. It was 6 degrees according to the truck display and this was the first time this has happened. I can't imagine it's good for the engine to rev up when dead cold like that.
11 Lariat
6" lift, 37's, Moto Metals, H&S, SPE, JL SPL2K
scummins is offline
post #2 of 16 Old 02-01-2013, 06:43 AM
Quoted: 2 Post(s)
Yes the truck has a high idle on it I think it kicks in when the temp is below 15 or 20 degrees outside. Nothing wrong with it at all.
2011 F250 6.7 3.55 gears
20" wheels,
Tonneau cover,
Chrome mirror covers and door handles,
Line-X bed liner,
LED grille lights amber,
EZ-down tailgate,
Tinted windows,
3.5"Ready lift kit
Amp steps
Bigtwinharley is offline
post #3 of 16 Old 02-01-2013, 07:05 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Re: Super high idle when cold?
trucks since 7.3s do this.
It's fine to high idle when not under a load
I made my Samsung SGH-I997 send this.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 16 Old 02-01-2013, 04:20 PM
BIG Laing's Avatar
I see 1100-1200 rpm every night after leaving work.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #5 of 16 Old 02-01-2013, 04:24 PM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
the high idle should kick off once you hit the brake
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #6 of 16 Old 02-01-2013, 05:15 PM
BIG Laing's Avatar
Something must be wrong with my truck then. My high idle kicks off when you shift into gear.
post #7 of 16 Old 02-01-2013, 06:03 PM
Quoted: 5 Post(s)
Thats when mine does it with the factory high idle too.
I did the high idle mod to my truck to help warm it up when its colder outside and it idles up to 1100. Helps it warm up faster and at when idling for a long period of time can prevent wet stacking.
Matt
2011 F350 6.7L CC/LB SRW 4x4 King Ranch White Tri Coat
31 YNOT is offline
post #8 of 16 Old 02-01-2013, 08:21 PM
mach14604's Avatar
Mine does the same thing. I have mine plugged in every night now below 20 degrees.
Want to Buy Ford Racing M-55 Exhaust
mach14604 is offline
post #9 of 16 Old 02-01-2013, 10:07 PM
BIG Laing's Avatar
I work night shift, so my truck sits in the cold while i am at work.
But at home it gets plugged in while it's chilly outside.
post #10 of 16 Old 02-02-2013, 08:38 PM
Clayton1985's Avatar
So you guys are saying hitting the brake doesnt kick down the high idle? That doesnt seem right.
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
