Lifted fuel mileage - Ford Powerstroke Diesel Forum
post #1 of 41 Old 01-31-2013, 10:08 PM Thread Starter
Lifted fuel mileage
Just lifted my 2012 cc diesel. I only lifted it 4.5 inches with 22s and 35s and the fuel mileage went from 17.5 at 75 to 14.5 mpg. I was wondering if this is normal for such a small lift.
Hardtopz28 is offline
post #2 of 41 Old 01-31-2013, 10:47 PM
sombrero's Avatar
That is fairly normal with a lift. Keep in mind you are making an already less than aerodynamic brick taller with more rolling resistance due to a larger/heavier tire. Fuel mileage will suffer. But, the cool factor is well worth it in my opinion.
2012 Ram 3500 Cummins-Work Truck
1997 F250 4X4 Crew Cab Short Box ZF-5 -Toy
sombrero is offline
post #3 of 41 Old 01-31-2013, 11:07 PM
BIG Laing's Avatar
What size tires did you have before? Are you taking into account the change in diameter? And hand calculating, or going off the lie-o-meter?
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #4 of 41 Old 02-01-2013, 04:15 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Your lucky it didn't drop less than that. Anytime you lift a truck this big your going to get some serious wind resistance going down the road. However, if you like the looks of your lifted truck than it's worth it. Everything in life has a compromise.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 41 Old 02-01-2013, 04:38 AM
hollywood1983's Avatar
I am getting about 17 to 18 mpg on the freeway at 70mph, city driving 15.5 mpg. I just got my mini maxx last week so I havent calculated yet.
2012 f250 fx4 lariat ultimate
2.5 ready lift stage 3
20x9 novakane wheels
S&b cold air intake
35x12.5 R2o
Fox 2.0 shocks
H&s mini maxx
5" flo pro exhaust
Egr block off plates
hollywood1983 is offline
post #6 of 41 Old 02-01-2013, 07:11 AM Thread Starter
The rims are 22x11 and guessing pretty heavy. The speedo is off by maybe 1 mph it's close to my gps. I couldnt be any happier with the way it turned out just wondering if it was normal. Not complaining cause with anything you have to sacrifice something.
post #7 of 41 Old 02-01-2013, 07:20 AM
Big_Smokey's Avatar
Quoted: 8 Post(s)
A good mount of that is due to the added weight in the tires and wheels. compare the weight to stock and im sure you will be shocked.
Big_Smokey is offline
post #8 of 41 Old 02-01-2013, 12:26 PM
BgCountry's Avatar
BgCountry is offline
post #9 of 41 Old 02-01-2013, 02:06 PM Thread Starter
Best pic I had I'm out of town and have not had time to shoot some good pics
post #10 of 41 Old 02-01-2013, 06:26 PM
Quoted: 6 Post(s)
Totally normal. I believe wind resistance is your biggest factor. Before my F350, I put 20" 33s on my Tundra, w/ XD Monster wheels & Terra Grapplers...no real change in MPG...
BUT, then I did a 3"/1" level lift...boom...went from 16.7 mpg to 14.2 mpg overnight. Sucked big time. Only explanation was a lot more wind was getting under the front end...which explains the OEM rake angle and low front end height...
2016 Cadillac Escalade ESV
2014 Mercedes E350 Sport
2012 F350 6.7L CCLB Lariat Ultimate SOLD
2007 F350 6.0L CCLB XL FX4
2010 F350 6.4L CCLB DRW XLT SOLD
1970 FORD TORINO COBRA 429
fosterelli is offline
