Is it possible to run any 37 inch tall tire on 20's, with factory suspension - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-31-2013, 05:30 PM Thread Starter
psi_2_high's Avatar
I am just currious to know if it is at all possible to run any 37 Toyo or Nitto , on an aftermarket rim on stock suspension?? I have a F350 and just have heard differnt stories and just wanted to no the truth, if anyone is pictures would be much appreciated , thanks alot guys.
2011 F350 FX4, Lariat, Recon Lights, more to come!!
2005 F250 ,Garret PowerMaxx, Studded, Bulletproof EGR Delete, 12" Rize quad link / King Coils / King Ress shocks, 4.56 Gears, Full HD interior, Straight Piped, Toyo 40/15.50/22 Fuel Hostage Deep Rim. And a ton more stuff i forgot!!
psi_2_high is offline
post #2 of 11 Old 01-31-2013, 06:26 PM
SlickYamaha's Avatar
I hightly doubt it. I just put 37's on my 6" lift and it rubs at full lock. I would assume you would need some big time trim'age!
-Jay-
Automotive Reviews and Install videos
'11 6.2L F250 Super Duty -- Crew
RollBak cover - Recon Smoked all around - 37" Toyo MT - 20" BMF Novakane - 6" Pure Performance Lift - Train Horns - Bulldog Lighting
SlickYamaha is offline
post #3 of 11 Old 01-31-2013, 06:36 PM
BIG Laing's Avatar
There is a guy on here that runs 37" tires with a 2.5" leveling kit. He says he rubs at full lock. The tires looked like they are stuffed into the wheel wells. I will try and find his thread.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #4 of 11 Old 01-31-2013, 06:44 PM
BIG Laing's Avatar
here it is http://www.powerstroke.org/forum/6-7...t-yes-sir.html
The problem I see for you, is the stock wheels are only 8" wide... I see Nitto makes a 35.5" tire for an 8" wide 20" wheel, but that is about the biggest.
post #5 of 11 Old 01-31-2013, 06:58 PM Thread Starter
psi_2_high's Avatar
So if im understanding this correctly..I could fit a set of 37x12.5 nitto with a zero offset on a BMF 20x9 wheel on stock suspension ??
post #6 of 11 Old 01-31-2013, 07:23 PM
BIG Laing's Avatar
He fit 37" tires with minor rubbing of the inner radius arm (at full lock). With a 2.5" leveling kit, and 9.5" wide wheels with a +20 offset.
They will NOT fit without a leveling kit.
post #7 of 11 Old 01-31-2013, 07:24 PM
BIG Laing's Avatar
And I would imagine you would have major rubbing issues on the outside edge of the tire with a 0 offset.
post #8 of 11 Old 02-01-2013, 06:28 AM Thread Starter
psi_2_high's Avatar
he was also on a 22 inch rim, i was just currious about a 20 inch
post #9 of 11 Old 02-01-2013, 03:18 PM
BIG Laing's Avatar
The diameter of the rim doesn't change anything for clearance. (Unless you were trying to go below 17", then you would have more issues).
post #10 of 11 Old 02-01-2013, 03:49 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
Rim size doesnt matter. Width and offset is where you have to get it right. i cant comment on the sizes for those trucks. As close to stock offset will give you the best results....however tires like mud grapplers with super aggresssive lug patterns could cause some rubbing on the inside.
Big_Smokey is offline
