6.7 EGR VALVE BYPASSES ENGINE - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-31-2013, 12:30 AM Thread Starter
Everyone that talks about the EGR Valve says they want to remove it because they want to stop the soot from going in the engine.
Found this info below
Link- Ford 6.7L Powerstroke Diesel Engine - EGR Valve - Diesel Power Magazine
Emissions System
The Scorpion's EGR system feeds exhaust from the passenger-side manifold at 1,472 degrees to a new, hot-side Pierburg EGR valve. This means the control of EGR flow is done before the EGR goes through the cooler-no other diesel in a pickup does this-in order to prevent EGR sludge buildup in the valve and engine.
The EGR valve housing is cooled and will be made of aluminum on F-250 and F-350 applications and cast iron on F-450 and F-550 applications. The EGR system uses two floating core coolers that can expand and contract to reduce the chance of failure. The EGR system also has a bypass feature that skips the cooler in order to get the engine to warm.
MR. EVO MR is offline
post #2 of 6 Old 01-31-2013, 01:18 AM
BIG Laing's Avatar
Emissions System
Interesting. Thanks.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 6 Old 01-31-2013, 06:15 AM
jrshelton13's Avatar
That is very interesting, learn something new everyday! I for one was under the impression that it did not bypass the engine/intake, after reading other post that commented on the amount of soot in the intake kind of makes you wonder. But I guess that it makes sense that you do not really need the actual exhaust to be recycled, just the heat to help reduce the NOx production. I think I will have to do some more reading on this. Thanks again!
jrshelton13 is offline
post #4 of 6 Old 01-31-2013, 07:31 AM Thread Starter
I almost feel that the tuner companies are just trying to push their products and misinform us consumers into thinking that our engines are being ruined.
So what happens? we remove and delete, blow up engines, loose factory warranty for what?
post #5 of 6 Old 01-31-2013, 07:39 AM
Idiesel's Avatar
Soot is still entering the engine. The only difference on this engine is the control of flow is done before the cooler where as 6.0s and 6.4s are done after. So in return the cooler doesn't get heat soaked and fail. If I understand it correctly.
Sent from AutoGuide.com App
Idiesel is offline
post #6 of 6 Old 02-10-2013, 03:37 PM
hw713713's Avatar
Trying to figure this out. Can someone please explain if I need to delete the cooler or just unplug and bypass? I have installed H&S with delete and S&b intake. Ordered the EGR delete as well just tryin to see the benefit.
2012 F250 KR, H&S mini max, full delete, Carli 2.5" pin top w/full replacement leafs, S&B intake, ADII and a camper shell!!!!
2013 Touareg TDi (mommas ride) She won't let me touch it.
hw713713 is offline
