Retro Solutions Installed Question - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-24-2013, 01:04 PM Thread Starter
farmcotton's Avatar
I have installed the 6000 55 watt headlight and fogs from retro solutions.
I have never had HID headlights or fogs before, but are the fogs suppose to be EXTREMELY bright compared to the headlights? im new to this and I was just seeing if this is normal, it takes them about 6 seconds to warm up and then they are bright bright!
2012 F-250 Lariat Ultimate
farmcotton is offline
post #2 of 9 Old 01-24-2013, 01:24 PM
DoubleDpsd's Avatar
Probably normal. 55w out of the fog lights would probably be pretty bright. I would have gone with a 35w for the fogs.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #3 of 9 Old 01-24-2013, 02:37 PM
Anth's Avatar
I am running 5k's on mine, yes they will be bright as heck way brighter than stock. You will pry not be able to run your fogs unless you are out in the country or on a less traveled road. If I am using mine I will turn them off when I meet a car. Also you might have to adjust your headlights down some.
2013 Platinum White, Dura Flaps, B&W turnover,
mpd s365 turbo kit, tuned by craig at mpd, no limit egr delete, amp steps, icon leveling kit, ouo traction bars, 20x10 bmf wheels, 35 toyo mt, bushwacker fender flares, painted to match headlights with projectors, absolute performance ccv kit.
Anth is offline
post #4 of 9 Old 01-24-2013, 03:53 PM
Lf83's Avatar
Quoted: 14 Post(s)
They're not capped either like ur heads.
leveled 2011 F250
Fox 2.0 Shox
35x12.50x20 Toyo AT II's
20x9 Fuel Dunes
H&S MiniMaxx
5" MBRB 7"Tip
S&B CAI
Lf83 is offline
post #5 of 9 Old 01-25-2013, 03:11 PM Thread Starter
farmcotton's Avatar
Yeah I dont think Retro will do a swap with me, What could be a option? lightly tinting the fogs lense?
post #6 of 9 Old 01-25-2013, 03:43 PM
Lf83's Avatar
Quoted: 14 Post(s)
I had 6k 55w hids and they were both the same. Are u sure ur heads are 55w? Maybe they mixed up ur order? But yeah tint would do it. Go to pep boys or anywhere and get some 20% or higher.
leveled 2011 F250
Fox 2.0 Shox
20x9 Fuel Dunes
H&S MiniMaxx
5" MBRB 7"Tip
S&B CAI
Lf83 is offline
post #7 of 9 Old 01-25-2013, 03:50 PM Thread Starter
farmcotton's Avatar
Yeah both boxes read 55 watt. Is there any other way to tell?
post #8 of 9 Old 01-25-2013, 03:55 PM
Lf83's Avatar
Quoted: 14 Post(s)
Maybe on the ballast or wires. 6k should be whiteish in color not any blue. I think retro uses 2 different ballasts for their 55 and 35w.
leveled 2011 F250
Fox 2.0 Shox
20x9 Fuel Dunes
H&S MiniMaxx
5" MBRB 7"Tip
S&B CAI
Lf83 is offline
post #9 of 9 Old 01-27-2013, 12:38 PM Thread Starter
farmcotton's Avatar
Where did y'all hide your ballast box on the fogs and how did you ground them?
