New Owner... - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-16-2013, 09:14 AM Thread Starter
New Owner...
Hey guys new owner of a 2012 F350 SRW CC SB. I love the truck and runs great stock. I will be either doing a Carli or Icon lift later this year. I have been looking and read kind of mixed reviews on guys that actually have done the deletes. I had a 6.7 cummins that was deleted and ran like a champ. Some guys say they have turbo problems when deleteing. Is this a common problem or just rare when guys are running the trucks on hotter tunes. I just dont want to delete if there are common problems associated.
Pjosh6 is offline
post #2 of 10 Old 01-16-2013, 10:35 AM
JimNVA's Avatar
Congrats.....but you better post some pics pronto or the mafia will get you!!!
p.s. get the delete stuff while you can....
Tuxedo Black 2011 F250 Lariat FX4
Originally Posted by stan60 View Post
Probably one of those deals that you ask 10 guys and get 10 different answers. I'm keeping what I have. I like the look, I like the sound. I don't think you would ever notice the difference on the street. Maybe on the dyno, but I don't ride there.
JimNVA is offline
post #3 of 10 Old 01-16-2013, 10:46 AM Thread Starter
Okay I'll post some pics tonight.. Yeah I was thinking of ordering the hs while they can still be found for a decent price as using it down the road.
Pjosh6 is offline
post #4 of 10 Old 01-16-2013, 10:54 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Congrats on your New Truck.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 10 Old 01-16-2013, 01:15 PM
Bullitt1289's Avatar
Congrats on the truck! From what I've read on here I think as long as you set the max boost to about 32/34psi you should be good. I'd look up your build date and make sure you have the newer style turbo first tho. Somebody correct me if I'm wrong but I think they switched mid 2012.
13 F250 FX4 CC Lariat Blue jean metallic
01 Mustang Bullitt #1289
02 F250 XLT 7.3 (sold)
SSgt USAF
Bullitt1289 is offline
post #6 of 10 Old 01-16-2013, 02:15 PM
OCVeloMan's Avatar
Quoted: 183 Post(s)
Garage
Congrats on the truck. The emission equipment doesn't seem so bad. Sage Carli beats his 2011 to death. Hell, he snapped an axle he runs it so hard but not a lick of trouble from the motor after 60K of abuse. Good luck with your build!
OCVeloMan is offline
post #7 of 10 Old 01-17-2013, 05:55 PM Thread Starter
Yeah everything I have read and reviewed shows Carli as a nice system. I look foward to finally getting the system. OC is there any downgrade if I am going to be towing with it. I do not tow a lot or heavy but would still like a lift kit that changes nothing.
Pjosh6 is offline
post #8 of 10 Old 01-18-2013, 08:55 AM
OCVeloMan's Avatar
Quoted: 183 Post(s)
Garage
That all depends on what you choose. If you go with an add-a-pack in the rear then you maintain your ability to haul a factory load. If you do full springs, the ride will be exponentially better but you lose 15% of your payload capacity. You can add our long-travel airbags to either setup to bring the rear end up to level when towing within the GCWR of the truck. We offer several scenarios so you would just have to decide which is right for you!
post #9 of 10 Old 01-18-2013, 09:20 AM Thread Starter
Okay. I plan on going with just the add a pack as of right now.
Pjosh6 is offline
post #10 of 10 Old 01-18-2013, 09:36 AM
OCVeloMan's Avatar
Quoted: 183 Post(s)
Garage
Then you'll maintain factory payload!
