Camper Shell Electrical Wiring Question - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-12-2013, 09:47 PM Thread Starter
I have a Leer XR camper shell on order; dude says he'll hook up the 12V light and 12V outlets right off the battery. Would there be any advantage (or disadvantage) to making the connection to an up-fitter switch instead? My thinking is that I could better control a potential battery run-down situation (ex: light left on) that way. I have no idea if this would be even feasible.
Could someone with more knowledge than I please chime it?
Thanks in advance.
JSolve is offline
post #2 of 9 Old 01-13-2013, 08:31 AM Thread Starter
I retract the question (as I don't see a way to delete the above post).
I have found out that the up-fitter switches only work key-on so my idea of using them will not work in this case.
JSolve is offline
post #3 of 9 Old 01-13-2013, 09:12 AM
theplumbingmedic's Avatar
i read something awhile back about that pre 08 there was an easy mod for keeping the upfitter switchs live when key was off. Do a search for it if thats your situation. I honestly can`t remember where i read it but it was on here
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
post #4 of 9 Old 01-13-2013, 09:20 AM
ZMANN's Avatar
Quoted: 1465 Post(s)
that 12v light would need to be on a long time to kill two healthy batts
the light I would like to come on if I open the door at anytime so IDK if I would do anything different ? however I wouldn't run to the battery I would get 12 constant from the trailer harness
We Miss you Ronnie
ZMANN is offline
post #5 of 9 Old 01-13-2013, 09:42 AM
Quoted: 2 Post(s)
why not hook it to the rear cab bed light? switchable on, or key on.
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #6 of 9 Old 01-13-2013, 09:46 AM
ZMANN's Avatar
that's an idea it would also come on with the cab doors
just not if the truck was off and cab lights off and you lifted the camper top or wanted it to switch on from in the camper
We Miss you Ronnie
ZMANN is offline
post #7 of 9 Old 01-13-2013, 09:56 AM
Quoted: 2 Post(s)
Hit the unlock on the key fob
jcain is offline
post #8 of 9 Old 01-13-2013, 10:00 AM Thread Starter
Thanks - that might have been here: Howto make Upfitter switches live all the time
JSolve is offline
post #9 of 9 Old 01-13-2013, 10:31 AM
ZMANN's Avatar
Seems pretty simple
I am not sure if I want them hot all the time Hmmm ???
We Miss you Ronnie
ZMANN is offline
