Diesel Additives - Ford Powerstroke Diesel Forum
post #1 of 17 Old 12-31-2012, 05:26 PM Thread Starter
mach14604's Avatar
Diesel Additives
I live in Northwest Ohio. The temps are starting to drop into the teens at night was wondering if i should be put additives in the diesel to keep in from gelling at night. if I should what kind does everyone use in the winter time? Thanks!
mach14604 is offline
post #2 of 17 Old 12-31-2012, 05:30 PM
HarvestingInternationally's Avatar
Usually the white bottle of power service diesel clean
http://img716.imageshack.us/img716/2580/oppt.jpg
2006
F250 Crew Cab Long Bed 6.0 TurboDiesel FX4
Diesel Site Coolant Filter, Edge Insight CTS, BPD FICM 48v, Metal CAC Tube, Blue Spring,Sinister Diesel EGR Delete w/ Up Pipe, Riff Raff Boots, MBRP 6212-409 Exhaust, BFG AT's,
Bilstein 5100's with Leveling Kit, ISSPRO EV2 Gauges (Pryo
, Fuel Pressure)
Eric
HarvestingInternationally is offline
post #3 of 17 Old 12-31-2012, 06:18 PM
I use the Ford brand on all our powerstrokes
Sent from my iPhone using AutoGuide.com App
cooper09250 is offline
post #4 of 17 Old 01-01-2013, 04:21 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
I use the motorcraft anti-gel and performance booster. not taking any chances with the warranty here. You can also add the the cetane booster since the anti-gel has no CB just performance enhancer.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 17 Old 01-01-2013, 10:01 AM
Quoted: 14 Post(s)
Motorcraft has two product.
PM-22 has a cetane boost but no anti gel
PM-23 has a Anti-Gel but no Cetane boost
I want booth in the winter, so I use the Opti-Lube XPD, has both Cetane, Anti-gel and one of the better lubricity improvers. But you will rarely find it in a store. You need to go to their website to buy it.
Power Service is available at almost any walmart, truck stop, farm store. The white bottle does Cetane and anti-gel. I usually can find it for half the price that walmart sells it for at my local farm store,
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #6 of 17 Old 01-01-2013, 10:14 AM
in the summer spring and fall i run archoil 6200 im not sure it has anti gel properties
2006
, Fuel Pressure)
Eric
post #7 of 17 Old 01-01-2013, 12:01 PM
I have only used the power service anti-gel(white bottle). I like to use something that is available almost anywhere. The Power Service products are available in my area (Wyoming) at most gas stations/truck stops, wal-mart, ect.
cruiserwy is offline
post #8 of 17 Old 01-01-2013, 12:34 PM Thread Starter
mach14604's Avatar
Can you pour both of these in the tank at the same time? Or do you like alternate?
post #9 of 17 Old 01-01-2013, 01:22 PM
BIG Laing's Avatar
Yes. Been doing it since temps dropped below 20. Also this is what I was told to do by the service guys at the stealership.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #10 of 17 Old 01-01-2013, 09:31 PM
Quoted: 14 Post(s)
Why would you do that? Twice the cost of just using a product that has the right mix of ingredients for the season. Plus twice the hasle of mixing two additives.
I'm sure the stealership would recommend it. You are spending twice as much at their parts counter.
I use Opti-Lube most of the time and especially in the winter months. If I don't have any Opti-lube with me, I'll use the Power Service white bottle during the winter. The only Motorcraft I've used was the PM-22 during the summer months.
