Towing up canyons - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-29-2012, 03:18 PM Thread Starter
Towing up canyons
I'm shopping for a fifth wheel and I'm probably going to end up with a loaded trailer at 16,500 #'s (pulling double). My truck is a F350 W/3.55 rear drive. What speed can I expect to pull up a 6% canyon like Parleys out of Salt Lake?
Red F350 is offline
post #2 of 11 Old 12-30-2012, 03:25 PM
BIG Laing's Avatar
You may want to look into re gearing to 3.73's if you are going to be pulling 16.5k often. I don't think you will have trouble doing 55+ Up parleys. If you want to play it safe get an edge CTS to monitor your vitals.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 11 Old 12-30-2012, 08:04 PM
I wouldn't think you would have to re-gear. Just lock out sixth if need be.
2012 f250 Ccsb Ultimate Lariat, Powerstroke FX4- Tuxedo Black, Bakflip F1
Lrdchaos is offline
post #4 of 11 Old 12-30-2012, 10:09 PM
I'd guess you will be at about 50 mph in fourth gear, maybe less. I've never pulled anything close to that heavy with this truck though.
2011 F350 4X4 CCSB SRW, King Ranch, 3.55, Mini Maxx, 4 inch exhaust, egr gone, Confederate Diesel turbo kit with a S363 and 0.91 twin scroll turbine housing, and stock air filter.
DirtBikePilot is offline
post #5 of 11 Old 12-31-2012, 07:57 AM
6.0f250firstcar's Avatar
If you lock it out of OD, you should be able to do 55 or so.
Sent from my iPhone using AutoGuide.com Free App
Ryan
6.0f250firstcar is offline
post #6 of 11 Old 01-01-2013, 04:23 AM
BIG Laing's Avatar
Over drive on our trucks are 5th and 6th gear. Just in case anybody doesn't know...
post #7 of 11 Old 01-01-2013, 04:29 AM
I did not know that thanks for clarifying that
Ryan
post #8 of 11 Old 01-01-2013, 09:55 AM
Quoted: 13 Post(s)
I have not had to lock out. The truck picks the right gear to stay in the right RPMs for the power needed.
It doesn't matter if its Trappers loop by Ogden, Parleys, Daniels, or Logan canyon, The tranny will downshift to keep the engine in the powerband. Some grades you will not ascend at 70 mph. But I have found if I can keep my speed up and not get caught behind a slow mover, that I can usually stay pretty close to the speed limits. At least with my 13,000lb trailer.
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #9 of 11 Old 01-01-2013, 10:28 AM
WOW, I guess I need to swap for a 6.7.
When I pull my double rig, 16K 5er(rated at 16K but usually weighs in at 17.5 or 18) and a 4wd Rocky behind, up the 6-8% grades in Colorado, I hit them at 70 then slowly work my way down to 3rd gear hoping to hold 30-40mph as I top out. Straight piped(magnaflow glass pack) no CAT with a tuner!! And 4.10 gears
2006 built 05/05 XLT CC DRW PSD. Captain chairs, sunroof, polished aluminum wheels, 6speed, manual 4x4. 285K miles with 130K problem free miles on new engine.
RatherBNtheWoods is offline
post #10 of 11 Old 01-04-2013, 01:21 AM
BIG Laing's Avatar
Yeah, these trucks are awesome. My 6.7 with 3.55's out tows my Bro in-laws 6.0 with 4.10's all day long.
