Where to connect Recon cab lights??? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-27-2012, 09:31 AM Thread Starter
cd4899's Avatar
Santa brought me a new set of Recon cab lights for my truck and now I'm wondering where is everyone connecting them for power??? Is there a plug in the dash somewhere?
2012 F350, Lariat, FX4, CCSB, ReadyLift 3.5" SST, 37" Toyo Mt, BMF Novakanes 20x9's, Firestone air bags, Air-Lift 72000, Rigid D2's
cd4899 is offline
post #2 of 7 Old 12-27-2012, 10:31 AM
Big_Smokey's Avatar
Quoted: 9 Post(s)
If u have lights already don't they just plug in? Adding them yourself i thought there was a plug under the headliner.a harness near the drivers pillar
Big_Smokey is offline
post #3 of 7 Old 12-27-2012, 10:49 AM Thread Starter
cd4899's Avatar
I didn't get them for the factory. I believe the complete harness would get replaced if I went with oem but I'm going with the recon lights and the have their own power feed. I just need to find a power source that's activated by the lights.
cd4899 is offline
post #4 of 7 Old 12-27-2012, 10:59 AM
Tuxedoblack's Avatar
If the harness is there in pillar post, tie in there and they should work with normal parking lights.
Tuxedoblack is offline
post #5 of 7 Old 12-27-2012, 02:08 PM
Does you truck have cab lights already and you are replacing them with Recon or are you installing them and drilling holes?
frt2599 is offline
post #6 of 7 Old 12-27-2012, 02:17 PM Thread Starter
cd4899's Avatar
It did not come with them so I'm starting from scratch.
cd4899 is offline
post #7 of 7 Old 12-27-2012, 02:26 PM
I installed them on my truck. The pucker factor is drilling 15 holes in the roof of your truck (three per light). Here is a very good thread on the install including removing the head liner. If you truck don't currently have them installed you don't have a harness already there, so you will need to run the Recon harnass. There is a wire under the driver side door sill you can tap into. Not sure what the wire color but it covered in this thread. Good luck, you will love them. Did you get the smoked or clear? You will need to add the side mirror lights now to match
RECON LED Cab Light Install with Pictures - Ford Truck Enthusiasts Forums
frt2599 is offline
