First Maintenance - Ford Powerstroke Diesel Forum
post #1 of 13 Old 12-10-2012, 06:16 PM Thread Starter
Quoted: 11 Post(s)
First Maintenance
Broke 4,300 miles today and gave the truck it's first everything...
Oil change (Wix filter, Castrol Tection 15W-40 oil)
Fumoto Valve N Series drain plug
DEF fluid top-off (computer says I was below half)
Drained the water separator filter
Gotta say, I love working on this truck!
2016 Cadillac Escalade ESV
2014 Mercedes E350 Sport
2012 F350 6.7L CCLB Lariat Ultimate SOLD
2007 F350 6.0L CCLB XL FX4
2010 F350 6.4L CCLB DRW XLT SOLD
1970 FORD TORINO COBRA 429
fosterelli is offline
post #2 of 13 Old 12-10-2012, 06:19 PM
Quoted: 2 Post(s)
A Fumoto valve! I didnt buy one because I love the drain plug Ford put in stock.
But yes I will say Ford made these trucks very eary to work on.
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #3 of 13 Old 12-10-2012, 06:19 PM
6.0f250firstcar's Avatar
Sounds good
Ryan
6.0f250firstcar is offline
post #4 of 13 Old 12-10-2012, 06:24 PM Thread Starter
Quoted: 11 Post(s)
I don't mind the OEM drain plug...but I do mind the 8 foot stream of oil that shoots out at high pressure! The Fumoto N-Series has a hose nipple, so I can plug a hose onto the valve and drain straight into my drain pan...no mess, no oil on my hands, no high pressure spray!
post #5 of 13 Old 12-11-2012, 08:04 PM
Quoted: 14 Post(s)
Just set a 5 gallon bucket under the oil drain and it catches that high pressure stream and you are drained in nothing flat. Never had a problem catching it.
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is online now
post #6 of 13 Old 12-11-2012, 11:23 PM
Did you have to take a piece off of the pan to put the Fumoto on? I noticed the valve they sent has a regular thread but the factory plug is like a 1/4 turn.
*SOLD*2008 F250 6.4: H&S Mini w/ Bully dog mount, Flo-Pro DPF/CAT delete, AFE stage 2, Viper 5901 Remote start.
2012 F250 6.7: S&B CAI, H&S Mini Maxx, 5" MBRP straight exhaust, Firestone airbags.
Grunnsetning is offline
post #7 of 13 Old 12-12-2012, 05:21 AM
here pictures of mine, i ended not using it after two oil changes cause it restricts alot, i also installed a cap cause of the stories of tumbleweeds opening this valves.
ID:	46933   Click image for larger version
ID:	46934   Click image for larger version
2012 f250 Ultimate Lariat, 6.7 powerstroke
Hunter69 is offline
post #8 of 13 Old 12-12-2012, 05:27 AM
what scared me , was that it was too easy for anybody to mess with it, now its sits collecting dust.
Hunter69 is offline
post #9 of 13 Old 12-12-2012, 05:29 AM
i wounldnt install it on a 1/4 turn pan, too easy to wiggle out. but again its just my two cents
Hunter69 is offline
post #10 of 13 Old 12-12-2012, 05:36 AM Thread Starter
Quoted: 11 Post(s)
My pan is metal and my drain plug was normal, not 1/4 turn.
