What drivetrain setting when it snows/slippery? - Ford Powerstroke Diesel Forum
post #1 of 32 Old 12-08-2012, 02:08 AM Thread Starter
Hi guys,
I have a 2012 f350 4x4
When it starts to become slippery outside, what setting do you put the truck in.
Lock the rear?
4x4 high?
Thanks!
MR. EVO MR is offline
post #2 of 32 Old 12-08-2012, 05:47 AM
I keep her in 2 hi when i feel like fishtailing and donuts in parking lots and 4hi when i need to stay out of the ditch say when i got the skinny pedal down to pass the slow car on the slick road. Ill put it in 4lo almost never. Good luck and keep it on the road
Sent from my DROID RAZR using AutoGuide.Com Free App
08 CC SB
Fun Stuff
Mini Max / S&B Intake / 4" MBRP DP / 5" MPRP DP Back / 5" x 6" x 18" MPRP BLACK Tip
Normal Stuff
10" shallow RF sub w/ custom box & amp rack / Xtant 600W amp / Tinted front windows to match factory rears / Recon bed lights
08SuperDiesel is offline
post #3 of 32 Old 12-08-2012, 05:58 AM
camdenlake's Avatar
Quoted: 15 Post(s)
Was thinking this today. What would 4lo do? Man that would be some tuging power.
As for snow i would say just drive it. If it gets out of shape it will correct. Does a good job. I will use 4hi if its real messy. I am assuming your have the advance trac and all that. I have used the locker only a few times when pulling on a loose surface but it turns off at 20mph?
Josh
1999 F150 4x4 With the not so stock V10
2009 Shelby GT500 - Grabber Orange
2012 F350 6.7 CC SB FX4 - Sold
2015 Explorer Sport - Black on Black - Sold
camdenlake is offline
post #4 of 32 Old 12-08-2012, 06:18 AM
Tuxedoblack's Avatar
Slick
Just 2 hi till it gets real bad or getting thru deep stuff, Ice doesnt know differance beween 2 and 4 spinning loaded or empty. Longer wheel base should do alot better. Always good idea to have few sandbags.
Tuxedoblack is offline
post #5 of 32 Old 12-08-2012, 06:28 AM
6.0f250firstcar's Avatar
I'd put it in 4hi and keep it there until it gets less messy.
Ryan
6.0f250firstcar is offline
post #6 of 32 Old 12-08-2012, 07:27 AM
Dieseldawg2010's Avatar
Having a a rear locker engaged while making turns on snow or ice will cause you to fishtail or loose control if you are not careful of your speed. You should only have it on when you need some serious straight ahead traction. I believe it automatically opens up at a certain speed anyway.
4 hi should be plenty and that depends on your tires as well. The stock tires suck on these trucks.
New:
2012 F-350 Lariat CC LB 6.7L 3.55 gears w/E-Loc, Lariat Interior Package, Moonroof, FX4
Air Train Horns/4.5" Carli Starter System/Carli High Mount Stabilizer/XD Rockstar II Matte Black 18x9 5" BS/37x12.50x18 Pro Comp Xtreme AT's/2WD Chin Spoiler
Gone May 2013:
2011 F-250 KR CC SB 4x4 6.7L 3.55 gears Nav System
Gone Feb. 2011:
2004 6.0L, F350 CC 4x4, 10" Icon Lift, 4.56 gears, lockers, Moto Metal 20" wraped in 38" MT's
Dieseldawg2010 is offline
post #7 of 32 Old 12-08-2012, 08:06 AM
Yeah it opens up at 20.
Ryan
post #8 of 32 Old 12-10-2012, 01:46 AM Thread Starter
Thanks guy's!
post #9 of 32 Old 12-21-2012, 02:33 PM
Driving in snow???
I drove my 2008 4x4 all over N Cal working after a heavy wet snow that then froze at 14-20 degrees with a wind. I put studded tires on, and rock n rolled... cautiously. Cruising 65-70 on snow covered roads, slowing down of course for corners... I took my 2011 up to Flagstaff after a winter snow to play, tires (BF Goodrich A/T's) ARE EVERYTHING!!! Well, right behind some common sense, always know your traction limits...
I keep it hi 4x4, and watch out for the other guy...
My 2007 (BF Goodrich A/T's) I drove in Ohio in ice n snow having fun, always mindful of the weight and speed of my vehicle...and my traction.
Bottom line...basic physics..an object will maintain its present trajectory unless acted on by another farce... or something like that....
Experience gained with patience, erring on the side of caution will keep you from being the guy that tells the tow truck operator "the salesman told me it would go anywhere."
I also put my truck in 4x4 in heavy rain..
Driving: 2011 Pale Adobe...F-350 CC 6.7 FX4 3:55-Locking Rear End-Dual Alternators-premium Lariat, moon rf, added wheel flares, 2-tone black base
Picked up 4/29/10 as of 08/31/2012 116,000+ miles
2009 6.4 CC 4X4 Bought new, 85,125 miles traded
2007 F-250 6.0 CC FX4 Bought used-traded
1999 F-350 7.3 CC SRW Bought New
Totalled- T-Boned F-150
Protected 9 occupants
Former Rides; Drove em like I stole em..
94 Dodge Viper
73 Corvette
23 T-Bucket w/ 427
68 El Camino w/396
richc22c is offline
post #10 of 32 Old 12-22-2012, 01:02 PM
Well bottom side of Draco left few inches of snow, took Truck out for a just gotta see run few miles, few dift places. Didnt use any of 4x4 options other than 2 wheeling, Driving nomal no issues, long wheel base done great. heavy drift areas where snow is deep it did pull but thats expected, throttle in corners yea it will spin, Stock Michiens did ok. Only trouble was took way to long to clean windows, cover should help with that. Ride it in 2 wheel drive unless you playing or working!
