2012 250 Leveling Spacer - Ford Powerstroke Diesel Forum
post #1 of 13 Old 11-21-2012, 06:43 AM Thread Starter
What size spacer do i need to level the front of a 250? 1", 2" or 2.5"? I want to do this without adding blocks in the rear and spending 2k on a full blown lift.
There are 3 sizes to choose from, dont know what I need because I dont have the truck yet!
Many thanks,
rbevard is offline
post #2 of 13 Old 11-21-2012, 07:08 AM
An F250 with a 2.5" leveling kit will have some Cali Lean. (NOSE UP IN THE AIR) I say maybe a 1.5 will put you level with the rear.
An F350 with a 2.5" leveling kit will put you even with the rear. I have also noticed that since the F350 sits higher from the factory, Adding a 2.5" leveling kit puts you right around the same height as a F250 with a 4" lift.
KING RIZZLE is offline
post #3 of 13 Old 11-21-2012, 10:00 AM
vlxjim's Avatar
Not completely true. The F350 is 1" taller in the rear do to a 1" taller block. When you lift a F250 2.5" you need to change the rear blocks to 4" - 5". Where with the F350 most will leave the stock 3.5" rear blocks on. This give the F250 .5" to 1.5" over the F350. If you change the rear blocks on a F350 they would be the same. If your were to put a 4" lift on a F250 or F350 they would be the same.
To the OP: Go with 1" or 2.5" with 4" rear blocks. 2.5" would be the best. That said don't forget the track bar. If you lift your truck your wheels will shift to the left .5" for each 1" of lift. To get your wheels back in track an adjustable track bar is needed.
2011 F250 PowerStroke CCSB Lariat FX4 Loaded | Icon 2.5" Stage 2 | Icon track bar | Top Gun Dual Stabilizers | 20" Fuel Boost wheels +1 offset | 325-60-20 Hankook Dynapro ATm | RBP RX3 steps | BakFlip F1 Bed Cover | All Sales Mfg Fuel Door | Randy Ellis Light Bar | Hella Lights | aFe Magnum FLOW Pro-GUARD 7 Air Filter |
vlxjim is offline
post #4 of 13 Old 11-21-2012, 11:32 AM
Any opinions of the ready lift stage 2 leveling kit? This includes track bar relocation bracket.
2011 F350 CCSB Lariat SRW
Readylift 2.5" leveling kit
Western SS MVP3 Plow
Hfd137 is offline
post #5 of 13 Old 11-21-2012, 03:33 PM
I agree with king razzle
jrod350 is offline
post #6 of 13 Old 11-23-2012, 10:46 AM
IIRC, the 350 blocks I put on my 250 were 1 3/4" taller? I have a 2.5 kit for the front, just have not put it on yet.
cmb396 is offline
post #7 of 13 Old 11-23-2012, 01:27 PM
Quoted: 2 Post(s)
I just bought a readylift 1.5 for front and 5" blocks for the rear for my 250. ive yet to get them though. How will my truck sit? It wont look goofy will it?
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #8 of 13 Old 11-24-2012, 06:13 AM
Well, your current rear blocks are 2" tall, so it's gonna set roughly 1 1/2" taller in the rear with some major rake.
cmb396 is offline
post #9 of 13 Old 11-24-2012, 10:26 AM
vlxjim's Avatar
Well I run 2.5" in the front and 4" blocks in the rear. And my truck sits dead level. Sounds like you'll be 2" higher in the rear.
vlxjim is offline
post #10 of 13 Old 11-24-2012, 08:16 PM
Quoted: 2 Post(s)
Do you need different shocks when you add the readylift blocks to the rear of a 250?
Your truck looks awesome by the way, got any more pics?
wreedPS is offline
