Starting problems - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-09-2012, 10:00 AM Thread Starter
Starting problems
Anybody have trouble with their truck starting? Mine is acting like it has dead batteries but even when fully charged, it will not start. It is at the Ford garage and the service manager told me that id it kicking the Master Tech's rear end. They replaced the batteries and checked all connection but still not wanting to turn over after it cools down.
Please help....
simmersm is offline
post #2 of 10 Old 11-09-2012, 10:26 AM
Made In America
Guardian29's Avatar
Hm. Not sure, did you try starting it while connected to another running vehicle? A battery can display full charged but just be shot. Either way I mean theres not a whole lot you can accomplish now while its at the dealer, post up any updates that you hear from them.
PHIL
'12 F250 CCSB, 35's, MiniMaxx, Deleted (Currently OOC)
'97 F350 CCLB, 6" Skyjacker w/ BDS and 35s, BTS tranny and HPOPs, 4.10s, H2E and stage 2 injectors, FASS 150, Banks intercooler, ARP head studs, IDM mod, DP tuner, WARN hubs, 6637, rear airbags
Guardian29 is offline
post #3 of 10 Old 11-09-2012, 10:29 AM Thread Starter
They replaced the batteries and it is still doing it. I know that I can't really do much but was hoping that someone with the same problem got theirs fixed and had a lead on what it might be.
simmersm is offline
post #4 of 10 Old 11-09-2012, 11:13 AM
Starter?
I had an issue that seemed like a dead battery a few years ago - the batteries tested fine - thought it was hydrolocked but, it ended up being the starter.
Caution: Buy a good one. I bought a no-name brand at first and had to do it again within a day.
01 7.3 f350 CC/SB - chipless w/3:73s
TrueCool Transcooler
FTVB
Gauges
AIS
Walker BTM
Bilstien 5100s
Soft top
daveyburt is offline
post #5 of 10 Old 11-09-2012, 11:16 AM Thread Starter
Guess i should have told everybody in the original post...
2012 XLT
13555 miles
Not worked hard at all!
It might be the starter. Have to see what the Ford Dealership tells me
simmersm is offline
post #6 of 10 Old 11-09-2012, 02:59 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Let us know.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #7 of 10 Old 11-09-2012, 05:58 PM Thread Starter
Update 11/9
Dealer tells me that they are going to replace the entire wiring harness and fuze panel. Tells me that there is a short somewhere. Will update when complete
simmersm is offline
post #8 of 10 Old 11-10-2012, 04:15 AM
Quoted: 4 Post(s)
Thanks.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #9 of 10 Old 11-11-2012, 02:23 PM
Exactly how does it act when you say it wont start when cold? reason I ask is that my 2011F550 has recently developed a cold start issue...
When I hit the key on mine first thing in the morning, the starter engages and tries to turn the engine but doesnt, its like the engine is hydrolocked ! I have to repeat this procedure about 5-10 times then the engine actually spins over and starts right up. I havent checked the coolant lately... no CELs.. Both batteries tested perfect, replaced them anyway, all connections clean and tight.
Was wondering if yours is doing something similar..
poormanscat is offline
post #10 of 10 Old 11-11-2012, 06:38 PM Thread Starter
It sounded and was acting like that it had dead batteries but would do it one time and then not the next. It started up fine when i took it into the dealer the first time and then if finally did it when the service guy was there. After having it for a couple days, thats when they decided to change out the fuze panel and wiring harness.
simmersm is offline
