cold weather warmup - Ford Powerstroke Diesel Forum
post #1 of 50 Old 11-07-2012, 05:07 PM Thread Starter
cold weather warmup
so i writing this thread to see what u guys think live in upstate new york where the cold is coming and own and love me some 6.7. So when i start it i let it idle to around 70 degrees then drive slow until the oil temp hits 100 then will start getting on it. so my question is does this work it is my first diesel and need it too last a long time plus like i said i love my truck.
hendrix6.7 is offline
post #2 of 50 Old 11-07-2012, 07:51 PM
Idling for extended periods of time in the cold is bad. You might think about switching to synthetic oil, if you want the best protection as well as using your block heater.
2012 FX4 XLT Crew Cab tuxedo black
Black2012 is offline
post #3 of 50 Old 11-07-2012, 09:12 PM
srjd's Avatar
Quoted: 2 Post(s)
look into getting your high idle hooked up but either way with emissions still on there its not good to idle
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #4 of 50 Old 11-08-2012, 12:30 AM
700xxmaniac's Avatar
It seams to me that the new diesel are take the cold a hell of a lot better the the the older ones. Hell the 6.7 don't even need glow plugs they fire right up without waiting even at 10*f..
99 ford f-250 crew cab powerstroke
-skyjacker 6'' lift
- 395-70r-16 mickey tomson baja mtz
-sct tune
-stright pipe (vrrrooom)
-cops are in love with the thing
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-kenda 22'' bear claw
-53mph top speed
700xxmaniac is offline
post #5 of 50 Old 11-08-2012, 10:10 AM
They have glow plugs, insta plugs, it takes them 2 seconds to reach temp, hence the 3 second delay in the remote start. There is an indicator on dash.
2012 F350 LB Lariat
Boat Hauler is offline
post #6 of 50 Old 11-08-2012, 11:49 AM
Can we get insta plugs 4 older engines
Sent from my ADR6400L using AutoGuide.Com Free App
-Mike-
2006 F-350 Lariat, Supercab, 6.0L, 3.73's...Rhinolined Bed...6 Spd Handshaker...Mag-Hytec Diff. Covers...Smoked Recon Lights...Amsoil oils front 2 back...Optima Yellow Tops...MBRP 5" ST8 Pipe, Turbo Back...Dieselsite Coolant Filter...Amsoil/Injen CAI...SCT SF3 Canned Tunes 4 Now...CFM Intake Manifold and Boost Tube...Blue Spring Upgrade...Edge Insite CTS !!!
pete37922 is offline
post #7 of 50 Old 11-08-2012, 11:53 AM
Galaxie's Avatar
6.7 takes a while to get up to operating temp and you really need to drive it to get there faster. Really I would get some heat in the motor and go. I have a 6L. If its not plugged in I wait until the 50s/60s to take off and just stay easy on it. Waiting for 100 takes a bit.
Just take off when she has some heat and be easy on here. If you are running a syn you will have a better time with it as well. Are you runing a 10/30 oil now?
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #8 of 50 Old 11-08-2012, 02:48 PM
They way I do it is just like I did my 6.0. I will start it with remote start and let it idle for a little bit (max 5 min) then I will get in and drive it down the road. The only thing is I don't let the RPM's get over 1800 while I am getting up to highway speed. Then I set the cruise.
2012 F250 Lariat CCSB FX4, Gooseneck and 5th wheel prep package, H&S Minimaxx, 5" AFE SS straight pipe, EGR delete with factory EGT sensor, 35" Toyo MT's on stock rims, and Bilstein 5160 shocks.
thomaslord84 is offline
post #9 of 50 Old 11-08-2012, 03:53 PM
PowerstrokeDriver2's Avatar
On my 6L i wait for the high idle to kick on for a few minutes then drive like my granpa did till she warms up
PowerstrokeDriver2 is offline
post #10 of 50 Old 11-10-2012, 12:25 PM
mugwump's Avatar
I have supplemental heat in my cab, and even when I remote start the engine it still takes a good 5 minutes to start to feel any heat. I know the supp heat is supposed to work right away, but mine don't. I also hear that the remote start will shut down after ten minutes if you don't get in it and go, is that right?
mugwump is offline
