Swapping 20's for 18's with 3.55 - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-21-2012, 07:41 AM Thread Starter
Like the title says I am looking at going down to 18's from my 20" wheels. I just like the look of 18's better than 20's. Will I sacrifice mpg by doing so? Will I need to get the speedo recalibrated?
Thanks
2011 F250 CCSB KR 4x4 FX4
chongo is offline
post #2 of 10 Old 09-21-2012, 10:50 AM
Bryce18's Avatar
Quoted: 19 Post(s)
Thanks
Doesn't matter wheel size for speedometer recalibration. What matters is whole wheel and tire diameter.
Sent from my DROID RAZR using AutoGuide.Com Free App
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #3 of 10 Old 09-21-2012, 10:54 AM Thread Starter
So if I go with a 285/75/18 (34.8") tire I should be fine?
Any issues or concerns with that much sidewall?
chongo is offline
post #4 of 10 Old 09-21-2012, 12:39 PM
My truck came with 18''s. I just put on 305/70r18's and now my speedo is almost right. When my speedo says 55 and I pass a laser speed sign it will say 56.
The 305/70r18 is 34.8" tall.
coryz71 is offline
post #5 of 10 Old 09-21-2012, 08:30 PM
Bryce18's Avatar
Quoted: 19 Post(s)
What size diameter is on your truck? If these new wheels and tires are bigger then your original ones. Your actual speed will be faster then your what your speedometer says.
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #6 of 10 Old 09-21-2012, 08:39 PM Thread Starter
I currently have 275/60/20
34.1 or 34.8 -whatever comes factory.
chongo is offline
post #7 of 10 Old 09-21-2012, 09:17 PM
Adventure Rider's Avatar
For the 305's did you change the rim width size to be more than the stock 8?
2012 F250 6.7 PSD XLT CCSB FX4 3.55 ELD Tuxedo Black Line-X, Weather Tech Floor Mats, Ford Molded Mud Flaps and Wheel Liners
Adventure Rider is offline
post #8 of 10 Old 09-21-2012, 11:03 PM
Quoted: 54 Post(s)
the oem 20's are 20 x 8 " the tire is a 275/65/20 275 MM wide by 65 % for sidewall hight
so do 275mm divided by .65 = actual sidewall height. convert to inches 25.4 mm = 1 inch
or convert the 20" wheel to MM
Take the wheel dia plus add the sidewall height x 2 and thats the over all rolling diameter
take the overall rolling dia and subtract that from the overall diameter on the 18" wheel/ tire combo. You then have your answer
2007 F250 CCSB Lariat Outlaw
U.S. Army OIF | OEF Veteran
Boudah is offline
post #9 of 10 Old 09-22-2012, 10:26 AM
No, stock wheels.
coryz71 is offline
post #10 of 10 Old 09-22-2012, 05:50 PM
Where r u located I want 20s and I have 18s
Sent from my LS670 using AutoGuide.Com Free App
2012 f250 4x4 stock
24ssm is offline
