Anyone here get around the 25mph Diff unlock? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-05-2012, 03:25 PM Thread Starter
Dman115's Avatar
I hate when the diff-lock on my truck turns off after 25mph!! Anyway around this? It would be alot more fun for messing around if it would stay locked. I've herd of people putting aftermarket lockers but am not sure how it works. thanks for any help guys.
Dman115 is offline
post #2 of 6 Old 08-05-2012, 06:57 PM
bbc109758's Avatar
Maybe someone knows whwt wire to bypass computer and then a job for upfitter switch. E-locker is just power to lock. Some one might know where to get schematics.
bbc109758 is offline
post #3 of 6 Old 08-06-2012, 04:50 AM
That would be a possible solution.
It's just two wires, a ground and power.
Personally I took the elocker out, I found it horrid on the street.
2012 F350, 6.7L Diesel, 4x4, SRW, Crew Cab, Short Box, Loaded, Ingot Silver
Detroit Truetrac, Icon leveling springs, steering damper mounts, King reservoir shocks and steering damper, Ultra Predator 22x10 and Nitto Terra 325/50R22 (35"s), H&S Minimaxx & Gearhead, aFe 5" SS w/ muffler, Leer XL, LineX, Titan 50gal, Airlift bags and wireless.
TrickTruck is offline
post #4 of 6 Old 08-08-2012, 11:04 AM
Blackie13's Avatar
E Locker and 25mph limit
I bet H&S or Spartan could figure it out and make it part of the option list on the programmer. This is my first Ford but I had a mini max on my 6.7 Cummins and you could do things like High beams with fogs, seatbelt miders could be turned off etc. I will look on their tech sites and forums to see if this was already suggested
Blackie13 is offline
post #5 of 6 Old 08-12-2012, 02:58 PM Thread Starter
Dman115's Avatar
Any more input from anybody?
Dman115 is offline
post #6 of 6 Old 08-12-2012, 04:19 PM
Baddestt's Avatar
Quoted: 9 Post(s)
A lot of guys replace it with a Detroit Truetrac, or a Detroit locker ...never understood why ford would set something up that unlocks at 25mph. These trucks are so heavy you need as much traction as possible...front and rear ends, IMO
'07 F-250 PSD 4x4
5" exhaust, zoodad, blue spring, Airaid intake, 6.4 starter, 2.5 f/coils, adj Trac bar, 2" r/add-a-leafs, egr delete, snow plow fan clutch, csf 6028 intercoolerr, DC 185 alt, Bilstein 5100, Barder '03 turbo rebuild w/RR billet wheel, SCT SF3 tuner, F-Detroit Truetrac, R-Detroit Locker, 4:10 gears, hawk LTS, LT315/70r17 Duratracs, Amsoil Gear lube, Delo 400 LE 5w30 diesel, Delo ELC, archoil, bpd ficm, BPD oil cooler, dynatrac pro steer ball joints, arp studs, oem gaskets, HD water pump, stc, plugs, stand pipes, 6.4 banjo bolts,
Baddestt is offline
