Rigid 20 inch light bar problem - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-24-2012, 08:32 PM Thread Starter
farmcotton's Avatar
I install a 20 inch light bar to my 2011 f250 and I can not get the upfitters switches to work. What did everyone do with the blue wire? I wired the red to the upfitter 1 and grounded the black.
2012 F-250 Lariat Ultimate
farmcotton is offline
post #2 of 3 Old 07-24-2012, 09:07 PM
fatheadon1's Avatar
It has been a while since i installed mine but if memory serves me right there is 2 bundles of wires under the dash with close to the same color wires an can be confused for the upfitter switche wires. So that is where i would start by checking to be sure you have the right wire for the upfitter. If you did not test your light before install you can test it off a drill battery to make sure the light is all good. An if none of that helps just call rigid and ask them,from my experience with their customer service it is 2nd to none.
2012 f350 ccsb diesel 3.55 eld fx4 9'6mvp hids 20'Ridge led bar ,325/60/20 duratracks, train horns,titan 50gal, sd truck 2.5 front springs,carli 6 pack rear,recon smoked ,tail,mirror,cab lights, B.F.C projector retrofit,titan 50gal, Whelen lin6,vertex strobes and SoundOff 1400 Lumen back up lights, , 05 f250 ccsb diesel, harley wheels 285/65/20 bfg A/t studded egr del MTW stage 2 warrens 155/stock sct xcal3,scangauge,add a leaf,Wide-OUT, Tornado 1.7 same strobes an back up lights as th 2012
fatheadon1 is offline
post #3 of 3 Old 08-23-2012, 03:55 PM
Farmcotton, did you ever get your light bar to work? I am getting ready to install mine and I am not sure what to do with the blue wire as well?
Where did you ground your black wire to?
Thank you,
offroadsd is offline
