Hitch question on my new 6.7 - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-22-2012, 05:12 PM Thread Starter
Traded my 6.0 on saturday for a 2012 6.7.. It came with a tow package and at first I thought it already had a gooseneck in it. I asked the dealer and they said it was like a Prep kit of some sort. I've had a B&W on all my other trucks but there is NO way it is going to fit in there with this kit (that looks like a hitch already) without taking the whole thing out. I posted some pics to explain it better. it looks like you could slide a ball down in there after you take out that cap but there is NO way that you would be able to lock the ball down so it wouldnt come out. Plus its only about 2 inches deep. Any of you guys see this or have this??
Jason1Pa is offline
post #2 of 12 Old 07-22-2012, 06:29 PM
atvrider93's Avatar
Quoted: 8 Post(s)
Thats really odd. when you take the cap off, what is the material in there? steel? if so could it just be a flipped over ball?
Edit: looked back at the picture and based on the holes it looks like thats not the case. does that inner part come out?
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #3 of 12 Old 07-22-2012, 06:44 PM Thread Starter
It may be able to be punched out. Its not very thick. I was told at the dealer that a B&W or Reese hitch could be put in,but the B&W's ball is square not round. I 'll call B&W Monday morning to see if they know anything
Jason1Pa is offline
post #4 of 12 Old 07-22-2012, 07:50 PM
Keel056's Avatar
Quoted: 4 Post(s)
It takes a "special ford ball" and it cost 200.00 from ford or 160.00 online. No other ball will fit. It is made by Reese.
Keel056 is offline
post #5 of 12 Old 07-22-2012, 08:07 PM
Powerstroke Techie
forddieseldoctor's Avatar
You have this installed from the factory:
Hitch Prep Package - 5th Wheel / Gooseneck | The Official Site for Ford Custom Accessories
You need to get this to be able to use it.
Gooseneck Kit | The Official Site for Ford Custom Accessories
Or this:
http://accessories.ford.com/5th-wheel-kit.html
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #6 of 12 Old 07-23-2012, 01:05 AM Thread Starter
Thank You so much for the info. This looks to be something that would be a pain after a while. Is it easy to take the ball out so I can have a flat floor or is it pretty much permenant? I wonder if I would just take the hitch out and put in a B&W like I want if the hole in the bed would be in the right spot? I would sooner not have this package
Jason1Pa is offline
post #7 of 12 Old 07-23-2012, 07:40 AM
Powerstroke Techie
I haven't messed with one, but one guy I talked to said it's easier to use than his b&w in his old truck.
Meet Double Aught
2000 F250
post #8 of 12 Old 07-23-2012, 08:18 AM
The Ford ball (and 5th wheel hitch for that matter) is real is real easy to install/remove. Not only does the kit come with the ball but you also get the safety chain points which go in the two forward holes.
thom12 is offline
post #9 of 12 Old 07-23-2012, 12:33 PM
Scubamax's Avatar
I wanted this in my truck so I wouldn't have to have the dreaded RAILS for my 5th wheel. It's the 5th wheel prep package like linked above. I'm not sure if you pull 5th wheel, but he Reese Elite that goes there is almost $2K!!! If you just want gooseneck, the ball is available through ford or reese. They did this to do away with the rails. In my opinion, the B&W is too heavy to move and remove.
94% of all Dodge Cummins trucks from1992 through 2012 are still on the road today..... The other 6% made it home.....
2012 F250 Lariat FX4
H&S Mini Maxx
Deleted MBRP 4" W/Muffler
EGT blocker plate
If it still runs when you delete it, you don't need it!
Scubamax is offline
post #10 of 12 Old 07-23-2012, 12:45 PM Thread Starter
I only pull a gooseneck so I just need to locate this Rese hitch. thanks!
Jason1Pa is offline
