E locker and exhaust brake??? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 07-01-2012, 01:43 PM Thread Starter
Tsgs69400's Avatar
Ok guys, How do you 6.7 owners like the function of the electronic locker and the exhaust brake in comparison to other trucks that you have or previously owned?
Can the locker be used while only in 2wd to aid in certain situations where 4x4 may not be necessary?
Does the manual trans function work like it should right on demand?
Ive been finding little issues here and there on my 08' 6.4 and cant help but check out the 6.7. I love the 6.4 and cant justify trading it with my finances being as they are but if it is going to turn into a repair nightmare in the future doing a trade up may be better in the long run.
Thad
2008 f-350 CCSB 4x4 6.4 Lariat Spartan Tuned, MBRP Duals, S&B intake, egr delete, ccv delete,custom coolant bypass, RF amps, Infinity Component Spkrs, Pioneer Shallow Sub, 13.9sec best
1996 f-250 Extended cab Short bed 4x4 7.3 5-spd, D60, Diamond Eye4" duals, DP Tuner, Stg 1 Injectors, DIY Intake, Custom Regulated Return Fuel System, Adrenaline,billet ww,Comp 910 springs, D66 Turbo, 6.0 Intercooler, SD rear springs,Custom trac bars, Truetrac diff.
Tsgs69400 is offline
post #2 of 15 Old 07-01-2012, 02:46 PM
My locker works in 2wd just fine. Used it in the sand last week.
2011 6.7 FX4 Lariat
TheBoss is offline
post #3 of 15 Old 07-01-2012, 02:51 PM
texas4x4's Avatar
The lockers work great in 4x2. As far as the engine brake when in tow haul mode it down shifts the transmission as soon as you start hitting the brakes. Takes a bit of getting use to buy like I said works great. I'm just not really sure why ford does an Auto/Lock on the hubs. You got any idea
texas4x4 is offline
post #4 of 15 Old 07-01-2012, 03:16 PM
barobbin's Avatar
Quoted: 3 Post(s)
the locker works great and on demand, as does the manual trans shifting. i have driven a couple 6.4's and overall i think it doesnt compare to the 6.7. love this truck
barobbin is offline
post #5 of 15 Old 07-01-2012, 03:23 PM
mazsecond's Avatar
Feedback Score: 4 reviews
The manual lock option on the auto hubs is for when you get stuck in 2WD and the truck can't move forwards or backwards to lock the hubs automatically, it can be quite useful in creation situations.
Mike
mazsecond is offline
post #6 of 15 Old 07-01-2012, 03:26 PM
texas4x4's Avatar
Thank you. Learned something new.
2012 F250 Crew Cab King Ranch 4x4
LineX Color Match Spray In Liner
UWS SD Tool Box
West in Grill Guard w/ Winch Mount
Warn M12000 bought to be installed
texas4x4 is offline
post #7 of 15 Old 07-01-2012, 03:28 PM
mazsecond's Avatar
I really wish Ford would offer a locking front end as well. I remember years ago saying "I wish Ford would offer a locking rear" and now they do, so maybe someday they will for the front as well, hell maybe even detroit lockers as an option on FX4 trucks??? Now that would be cool
Mike
post #8 of 15 Old 07-01-2012, 04:00 PM
Baddestt's Avatar
Quoted: 8 Post(s)
Ford just started offering a Torsen front limited slip for the 2013 f150 raptor, combined with the ford rear locker. That's what ford needs to offer in the super duty.
You don't need a full locker in the front unless it's selectable. With a rear locker and Detroit truetrac in front, you will have the traction to pull virtually anything out of ditch and go where you want to go. And it's great for snow.
I love this set up I have
'07 F-250 PSD 4x4
5" exhaust, zoodad, blue spring, Airaid intake, 6.4 starter, 2.5 f/coils, adj Trac bar, 2" r/add-a-leafs, egr delete, snow plow fan clutch, csf 6028 intercoolerr, DC 185 alt, Bilstein 5100, Barder '03 turbo rebuild w/RR billet wheel, SCT SF3 tuner, F-Detroit Truetrac, R-Detroit Locker, 4:10 gears, hawk LTS, LT315/70r17 Duratracs, Amsoil Gear lube, Delo 400 LE 5w30 diesel, Delo ELC, archoil, bpd ficm, BPD oil cooler, dynatrac pro steer ball joints, arp studs, oem gaskets, HD water pump, stc, plugs, stand pipes, 6.4 banjo bolts,
Baddestt is offline
post #9 of 15 Old 07-01-2012, 04:05 PM
mazsecond's Avatar
I forgot about the Torsen front diff in the raptor. That would be awesome if the offered it in the SD some day.
Mike
post #10 of 15 Old 07-01-2012, 04:36 PM
www.wilmingtondumpsters.comI am getting ready to put a front locker in my truck...it will be an ARB ...the locker is around a grand....the install is 350 by a great mechanic...I will finish installing the ARB dual compressor this week which was around 500 bucks..the manifold kit was 75 bucks...I am mounting it under the passengers seat and removing the ventilation tube so it will fit....any suggestions, advice..I will post pics
tonydumpsters is offline
