Leer XL cap for 11+ Superduty doesn't fit - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-27-2012, 12:33 PM Thread Starter
Went to pick up my new cap.
I was all doey eye'd looking at it on the forklift, then they set it on the truck.
First off, for those who don't know, this cap fits down over the side of the bed, sort of cupping the bed top.
So anyway, there are huge gaps between the cap and bed. Talking I can fit my big knobby fingers up in there. In one place my thumb fits in nearly to the knuckle. That's 1/2" to 3/4" for fingers and 1" for a thumb.
Needless to say, I did not accept delivery.
Leer said they sell tons of these and have never had this problem, but they will take it back to the factory and check it out and repair or replace it.
So my question is to those of you with leer XL caps: how do they fit?
Here's some crappy low res pics, will try to get the high res.
ID:	39583   Click image for larger version
ID:	39584   Click image for larger version
ID:	39585   Click image for larger version
ID:	39586   Click image for larger version
2012 F350, 6.7L Diesel, 4x4, SRW, Crew Cab, Short Box, Loaded, Ingot Silver
Detroit Truetrac, Icon leveling springs, steering damper mounts, King reservoir shocks and steering damper, Ultra Predator 22x10 and Nitto Terra 325/50R22 (35"s), H&S Minimaxx & Gearhead, aFe 5" SS w/ muffler, Leer XL, LineX, Titan 50gal, Airlift bags and wireless.
TrickTruck is offline
post #2 of 7 Old 06-27-2012, 12:33 PM Thread Starter
more pics
ID:	39588   Click image for larger version
ID:	39589   Click image for larger version
post #3 of 7 Old 06-27-2012, 03:18 PM
2006F350's Avatar
I had one on my 06 and 12 the gap is perfectly even all the way around.
Rich
KC Stage 3, FF 190/75, UCF Ported O-Ringed Heads, Warren Comp Plus Transmission, ARP, Sinister Up & Charge Pipes, ODAWG Ported Intake, Atlas 40, IPR EGR Delete, DD RR Kit , Fass 200, BD Exhaust, Mishimoto CAC & Radiator, BPD Water Pump, OUO Bars, MBRP 4 TB SS Duals, Sinister Coolant/Oil Bypass Edge CTS w/EGT & FP, SCT X4, DC Power 190 AMP, Hellwig Sway, No Limit Cold Air, Beans Sump, Gearhead Tunes
2006F350 is offline
post #4 of 7 Old 06-29-2012, 09:46 AM
Summitman's Avatar
Looks to me like a crappy install.
They all fit like that if you just set them on the truck & clamp them down. You have to set them on hte bed & move them around A LOT to get the gabs right, keep everything sealed, & so the rear door will work properly.
2001 F250 7.3 Lariat
2015 F350 6.7 Platinum
2015 F150 3.5 Platinum
Summitman is offline
post #5 of 7 Old 07-02-2012, 10:51 AM Thread Starter
It's not the install. The front was lined up perfectly and the cap was centered. The gap was huge, like 1.25" too wide of a cap where it meets the bed in the front. No way to 'pull' the cap in where it was bulged.
Leer took it back and is going to inspect it.
post #6 of 7 Old 12-23-2012, 08:10 PM
I swapped my Leer topper from a 2006 to a 2012. The only problem I had was the back glass door didn't close because the tailgate had the pull-out step. I just trimmed the metal off the bottom until it closed.
Silverspank is offline
post #7 of 7 Old 12-24-2012, 01:04 AM
Tuxedoblack's Avatar
Hopefully Leer will make it right for you
Tuxedoblack is offline
