Exhaust - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-10-2012, 05:14 AM Thread Starter
Suzuki6mx's Avatar
Exhaust
We have a new dump truck coming...what I'm asking is if I shorten the exhaust to come out in front of wheel instead of behind will that void any warranty at all?
2002 F350 ext cab SRW 6 1/2' bed(mine)
2008 F350 CC DRW 8' bed(Dads)
2012 Reg Cab DRW Dump
1996 Reg Cab DRW Dump
1999 Reg Cab DRW Dump (After a year of sitting its back and running good)
2003 Ext Cab DRW 8' Utilty
Suzuki6mx is offline
post #2 of 5 Old 06-10-2012, 08:46 AM
TRI
TRI's Avatar
Yes it will. Those holes are engineered for cooling.
Or are you reinstall the same tip it?
TRI is offline
post #3 of 5 Old 06-10-2012, 08:47 AM
Scubamax's Avatar
maybe if you cut the exhaust and reinstalled the ugly tip...
94% of all Dodge Cummins trucks from1992 through 2012 are still on the road today..... The other 6% made it home.....
2012 F250 Lariat FX4
H&S Mini Maxx
Deleted MBRP 4" W/Muffler
EGT blocker plate
If it still runs when you delete it, you don't need it!
Scubamax is offline
post #4 of 5 Old 06-10-2012, 08:48 AM Thread Starter
Suzuki6mx's Avatar
Yes same tip...I just need the exhaust shortened because backing
Into a paver will smash it...exactly same exhaust just shorter
post #5 of 5 Old 06-12-2012, 12:30 PM
Yes you can do this. I do not own a 6.7 but a good friend is a mechanic and just did this to a fleet of 4 2012's. He had to cut and shorten the tailpipes. He contacted a dealer or something and got the go ahead as long as the factory tips were re-installed. It was done for installation of flatbeds.
400kStroker is offline
