Back up Beeper with trailer - Ford Powerstroke Diesel Forum
post #1 of 15 Old 05-24-2012, 07:26 PM Thread Starter
How do you shut it up 6.4 had a button.
Profish00 is offline
post #2 of 15 Old 05-24-2012, 07:32 PM
Dieseldawg2010's Avatar
I just arrow down and press okay. I think when I have a trailer attached it automatically shuts off.
New:
2012 F-350 Lariat CC LB 6.7L 3.55 gears w/E-Loc, Lariat Interior Package, Moonroof, FX4
Air Train Horns/4.5" Carli Starter System/Carli High Mount Stabilizer/XD Rockstar II Matte Black 18x9 5" BS/37x12.50x18 Pro Comp Xtreme AT's/2WD Chin Spoiler
Gone May 2013:
2011 F-250 KR CC SB 4x4 6.7L 3.55 gears Nav System
Gone Feb. 2011:
2004 6.0L, F350 CC 4x4, 10" Icon Lift, 4.56 gears, lockers, Moto Metal 20" wraped in 38" MT's
Dieseldawg2010 is offline
post #3 of 15 Old 05-24-2012, 07:36 PM Thread Starter
Not sure just loaded the 4wheeler and Backed it back in the garage, was looking for the R button. Arrow down on what the camera?
post #4 of 15 Old 05-24-2012, 08:07 PM
on mine it has on/off that pops up on the info center. I just arrow down to off and press ok.
bmac4020 is offline
post #5 of 15 Old 05-24-2012, 11:25 PM
Bryce18's Avatar
Quoted: 19 Post(s)
X2 mine shuts off when hooked up to a trailer.
Like said above when you shift to reverse, there should be a message on info center, press up or down arrow to highlight "back up sensor" On or off.
Sent from my DROID2 GLOBAL
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #6 of 15 Old 05-28-2012, 01:51 PM Thread Starter
Thanks, got it. With Tow Haul button pressed it won't beep. also, I also noticed with tow haul button pressed the engine will help with breaking, or did I imagine it? With that said, do I really need to press the tow button pulling a 5x10 trailer with just a 4wheeler?
post #7 of 15 Old 05-28-2012, 04:16 PM
twin200's Avatar
I would say you don't, cause you don't need tow/haul on level ground or thats what the info center says. You can name your trailers and the truck will reconize them when you hook up and keep towing milage and brake gains. Pretty cool
2000 F-350 7.3 4wd cc,dually lariat
afe intake,programmer. rear airbags
2011 F350 6.7 cc,4wd shortbox lariat
Tinted windows Gray bedliner(diy)
Tool box Bull bar
Front aux lights Rear aux lights
Onboard air Train horns
Billet grille LED bed lights
Mike
twin200 is offline
post #8 of 15 Old 05-29-2012, 02:21 AM
airforcex2's Avatar
Do you have the Nav system? I have searched and searched for a way to shut mine off when the tail gate is dropped without success. Guess I need to look in the pwners manual.
2010 F-250 CC FX4 SRW, H&S, 5" Diamond Eye -- SOLD
2012 F-350 CC FX4 DRW, H&S
airforcex2 is offline
post #9 of 15 Old 05-29-2012, 10:50 AM
While the beeper is beeping, look at the display between the two large gauges (Tach and Speedo). Use the left,right,up,down navigation wheel on the left side of your steering wheel to hi-lite, NO, and press enter (center of the nav wheel).
You can lower the tailgate, connect a trailer without plugging in the wires or back up close to something to get the warning beeper beeping when the truck is running and reverse is selected. If you plug in a trailer wiring plug, the beeper does not sound in reverse because the truck knows something is back there since the trailer wiring is being used.
Hope that helps Air Force and many, many THANKS for your service!!!
2012 F450 Ultimate Lariat pkg, 4X4, FX4, 5th wheel prep, camper pkg, 40console40 seat, Ingot Silver and Black guts
Reese Elite 18k 5th wheel
BedRug liner
DuraFlap flaps all 4 corners
60 gal aux tank in bed
7.4 mpg as shown @ 70mph and 25740 lbs gross!!
2012 Fuzion FZ310 Monster Edition Toy Hauler 12,500 dry 16,500 loaded to play. 3100/3500 pin weight
Breast feeding is a hard habit to quit
mowdoc is offline
post #10 of 15 Old 05-29-2012, 01:40 PM Thread Starter
Mine still beeps with the connector plugged in.
