Dome light - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-21-2012, 03:19 PM Thread Starter
HPUyellowjacket's Avatar
Dome light
May be a dumb question, but i could not find out how to on google.
Does anyone know how to acces the dome lights if we have a sunroof. I got some Recon LED lights to put in but cant figure out how to get to the front lights.
New Truck
2012 Lariat FX4 Off Road, Tuxedo black, Custom paint to match grille, paint to match halo projector headlights, S&B intake, Amp Steps, RBP 94R black with chrome insert 20X9 wheels, 35 Nitto Trail grapplers
The Toy
2001 4x4 off-road extended cab, DP tuner, 4 inch turbo back, S&B filter, smoked projector headlights, Ranch hand fron & rear replacements, 18 inch fuel wheels, nitto trail grapplers.
HPUyellowjacket is offline
post #2 of 5 Old 05-24-2012, 10:34 AM
barobbin's Avatar
Quoted: 3 Post(s)
open the sunglasses holder and when its about halfway open you see a clip, push it with a screwdriver then i think it comes right out, i havnt done it in a while. also i hope you got resistors with those lights because it wont work right without them.
barobbin is offline
post #3 of 5 Old 12-26-2013, 07:27 AM
How do you remove the lens on the map lights and dome lights to install the LED bulbs. I have ordered the new bulbs but can not figure out how to change the bulbs. I have a 2013 F350 supercab.
STGFIREFIGHTER is offline
post #4 of 5 Old 12-26-2013, 08:05 AM
Ryan2012F350's Avatar
Garage
I just grabbed mine and pulled, it came out, didn't break!
As for the lens, if you look at it from the front (of the truck way) you'll see two little T shaped plastic tabs that have to go back as well as 1 hook shaped clip on each side.
Hope that makes sense. If you hold it upside down with the front facing you you'll see what I mean.
Ryan2012F350 is offline
post #5 of 5 Old 12-26-2013, 01:26 PM
That sounds scary. How about the map lights above the rearview mirror?
