First regen at 193 miles - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-21-2012, 02:11 PM Thread Starter
hopperwagonbob's Avatar
Is this normal? The lie ometer was at 20.5 when the Cleaning Exhaust Filter came on. Only reason I looked at the information center was the truck lost power an sputtered. Took the lie ometer down to 13.9 avg. Now it's going back up at 230 miles.
hopperwagonbob is offline
post #2 of 5 Old 05-21-2012, 05:22 PM
Hawkeye Diesel's Avatar
Yeah, when my truck was stock I would get a regen every 200-250 miles or so. Usually always twice in one tank of diesel. Just depends on your driving habits and whether you regularly pull things. The harder the engine works and the higher the EGT's, the more often it will do a "passive" regen, the more in town stop and go driving you do, unloaded, the more often you will get "active" regens, which is when your truck actually goes into cleaning the exhaust filter mode.
[/SIGPIC]2008 F250 Lariat, 8" lift 37x12.5 20 Nittos, Spartan tuned running 275 with an AFE stage 2 and 4" straight pipe. Next up, full EGR and Cooler delete
Proud to be a Union Steamfitter
Hawkeye Diesel is offline
post #3 of 5 Old 05-21-2012, 05:37 PM
Dieseldawg2010's Avatar
Yep, 32k miles on mine and it regens every 200 miles. It cost you about 1 mpg.
New:
2012 F-350 Lariat CC LB 6.7L 3.55 gears w/E-Loc, Lariat Interior Package, Moonroof, FX4
Air Train Horns/4.5" Carli Starter System/Carli High Mount Stabilizer/XD Rockstar II Matte Black 18x9 5" BS/37x12.50x18 Pro Comp Xtreme AT's/2WD Chin Spoiler
Gone May 2013:
2011 F-250 KR CC SB 4x4 6.7L 3.55 gears Nav System
Gone Feb. 2011:
2004 6.0L, F350 CC 4x4, 10" Icon Lift, 4.56 gears, lockers, Moto Metal 20" wraped in 38" MT's
Dieseldawg2010 is offline
post #4 of 5 Old 05-21-2012, 06:25 PM
The mileage part is normal but the loss of power and sputtering is not.
2011 F250 6.7 Lariat Ultimate FX4 CC Tuxedo Black Tan Bottom
stroke11 is offline
post #5 of 5 Old 06-19-2012, 07:58 PM
Kenjamin's Avatar
Quoted: 3 Post(s)
I always assumed the loss of power was normal because we have 4 work trucks all 6.4 and you can tell when they kick into "Cleaning Exhaust Filter" before it ever shows up on the screen because the engine noise changes and theres a noticeable change in power. So when that happens I look down to the screen and in about 2 seconds it will change to Cleaning Exhaust Filter. Should I be called Ford because all 4 trucks definitely lose power during the Regens. Also my personal truck seems to lose power as well during Regens.
2008 F-350 Harley Davidson Edition
- S&B Cold Air Intake
- Vista-Pro Radiator (Lifetime Warranty)
- H&S Mini Maxx Tuner
- Custom BLACK Ford Oval Emblems
- MBRP 4" Downpipe Back DPF/CAT Bungless Delete With Muffler, Stock Tip
- MBRP 3" Intercooler Pipe
- EGR Deleter Kit With Elbow
- Sinister Coolant Filtration Kit
Kenjamin is offline
