air horns - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-09-2012, 08:43 PM Thread Starter
air horns
Those of you who have air horns, how do you activate them. Do you have them wired directly to the upfitter switch or do you use the upfitter switch to control a relay to select between "normal" and air horns? It's easier to wire directly to the upfitter switch, but that's a long way to reach vs. hitting the center of the steering wheel. Any comments on which way is best?
2012 F250 CCSB w/Nav
countrylife is offline
post #2 of 7 Old 05-09-2012, 10:52 PM
Do a search, there are a bunch of threads of how to wire it to your horn button with a relay.
2011 F-350 CCSB
powerstroke43 is offline
post #3 of 7 Old 05-10-2012, 09:50 AM
jeepraptor's Avatar
I've got mine hooked to one of the upfitters...only problem I've ran into is having a cup in the way when someone pulls out infront of me etc...
jeepraptor is offline
post #4 of 7 Old 05-10-2012, 09:54 AM
barobbin's Avatar
Quoted: 3 Post(s)
there was a thread on here where some guy hooked his up to his upfitter as a selecter between normal and air horns. it looked relatively simple and he has a video showing everything he does. its very well done. ill try and find the link
barobbin is offline
post #5 of 7 Old 05-10-2012, 09:56 AM
Quoted: 356 Post(s)
Feedback Score: 5 reviews
I have the relay sitting in the glovebox as That was my original plan but ran out of time on the initial install...Now I have gotten used to flipping the upfitter to run the horn
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is online now
post #6 of 7 Old 05-10-2012, 10:00 AM
barobbin's Avatar
Quoted: 3 Post(s)
barobbin is offline
post #7 of 7 Old 05-10-2012, 04:03 PM
Alberta Advantage's Avatar
Quoted: 20 Post(s)
I used an upfitter/aux switch to power my compressor as a fail safe. If I have a leak in the line, I don't want my compressor constantly cycling as it will burn the compressor out. Therefore, I use the upfitter as a kill switch. If my tanks aren't holding pressure and the compressor is on for a significant amount of time, I can simply turn the switch off and kill power to the compressor. I then added a switch under the steering wheel, on the kick panel, that activates my air horn when in the "on" position or my factory horn in the "off" position. I did this because I have no idea what the legality of a train/airhorn is especially, when it is the same horn they use on fire trucks here. I used a relay for this reason. Here's some crappy cell phone pictures on my setup on y 6.4.
Horn mounted behind driver's side headlight
Switch below the steering wheel on the kick panel.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
