Aries 3064 Full Brushguard Review - 2011 F250 Lariat - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-08-2012, 10:38 PM Thread Starter
IronCobra's Avatar
Quoted: 9 Post(s)
So I was able to install my new Aries 3064 Brush guard on my 2011 F250 this past weekend. Here are my thoughts on this.
I chose this product over the Ranch Hand Legend series because I prefer the open grill look of this Aries better. I’m not a big fan of the punch plate that covers the big shinny Ford grill. Also, I prefer the way the sides curve to match the headlight profile better than the RH. I was able to actually see the quality of both at the shop. They had a damaged version of each that had been cut in half to show the different. The RH definitely wins here. The steel is not as big in diameter but is thicker (probably around 16awg vs 18awg with the aries. The RH is much heavier as well and has several areas that are reinforced vs. the Aries. The Aries does offer better headlight protection in terms of actually protecting the headlight from brush that may scratch or damage it. The Aries is also more likely to deflect rocks because of the cage that offers more coverage.
I don't believe either will really offer much protection against a hard impact or a side impact. They both are designed to stop brush and bushes from damaging your front end. They aren’t designed to prevent a 300lb deer or another car from damaging your car.
I prefer how the RH's reinforcement mounts are attached to the bottom of the frame. Though they both mount to the front of the frame, the Aries uses reinforcement brackets that are installed at the top rear of the bumper (to the actual bumper). This causes more movement than the RH.
Installation notes: The Aries was very simple to install ONCE you get the brackets on. The reinforcement brackets were a PITA because the 2 bolts you need to access are on the back of the bumper and you only have about 1.5" of space to work with. You will definitely want to get under the front of the bumper instead of trying to fit your hand behind the bumper from the front. After that it is about a 30 min install.
Overall, I definitely prefer the look, fit, and design of the Aries but prefer the reinforcement mounting, structure, and tube awg of the RH.
Both are very nice and will do exactly what they are designed to do.
BTW, I will be LineXing mine to match the trim in the next few weeks.
What you should pay for each
Ranchhand Legend Full brushguard (Not bumper replacement): $495
Aries Offroad 3064 1-Piece Brushguard (Black): $399
Aries Offroad 3064-2 1-Piece Brushguard (Stainless): $699
ID:	37787   Click image for larger version
2016 F450 Platinum FX4 CC LWB
2016 Chaparral 360IBL Fifth Wheel: 15,500lbs
GONE - 2011 F250 FX4 6.7L Lariat Ultimate
IronCobra is offline
post #2 of 5 Old 05-09-2012, 02:34 AM
Nice looking, I would prefer in chrome but like this it's better looking than mine.
F250 powerstroke lariat 4x4 2008 Lone Star conversions
Lance 815 slide-in-camper 2007
I'm French, living in Normandy
weymard is offline
post #3 of 5 Old 05-09-2012, 06:38 AM
if they aren't designed to protect you from deer and other cars, what are they designed for?
2012 F350, 6.7L Diesel, 4x4, SRW, Crew Cab, Short Box, Loaded, Ingot Silver
Detroit Truetrac, Icon leveling springs, steering damper mounts, King reservoir shocks and steering damper, Ultra Predator 22x10 and Nitto Terra 325/50R22 (35"s), H&S Minimaxx & Gearhead, aFe 5" SS w/ muffler, Leer XL, LineX, Titan 50gal, Airlift bags and wireless.
TrickTruck is offline
post #4 of 5 Old 05-11-2012, 09:05 AM Thread Starter
IronCobra's Avatar
Quoted: 9 Post(s)
I'm not trying to be a smarta** when I say this.....but it's a "brush" guard.
brush - definition of brush by the Free Online Dictionary, Thesaurus and Encyclopedia.
brush: A dense growth of bushes or shrubs
Brushguard: Designed to prevent front-end scratching caused by driving through high brush, hence the synonym "brush guard". In recent years, however, the term "brush guard" has been repurposed to apply to the headlight-covering portion as well.
Other than a full bumper replacement, hitting a several hundred pound deer (or several thousand lb car) a brushguard won't give too much protection.
post #5 of 5 Old 05-12-2012, 06:27 AM
Smoke Eater
Feedback Score: 5 reviews
Send a message via Yahoo to fdchief
Very nice cant wait to see it line x'd..
2007 F-250 Lariat Crew Cab
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
SCT Livewire w/ Tony Wildman Tunes
PMM Full EGR Delete/ Coolant Kit
Hornblasters 540 Kit
LED Lightiing All Around
All kinds of other Goodies!
2005 Lariat Crew- GONE!
2011 Lariat Ultimate Crew- GONE!!!
Back in a 6.0hhhhh and lovin it!
fdchief is offline
