Speed limiter - Ford Powerstroke Diesel Forum
post #1 of 19 Old 05-06-2012, 12:10 AM Thread Starter
Speed limiter
How do I get this thing off with out actually programming the truck for performance. I just want to go faster than 95.?
Hardtopz28 is offline
post #2 of 19 Old 05-06-2012, 05:30 AM
Term3's Avatar
Keep in mine your tires are only rated for 110
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 19 Old 05-06-2012, 05:38 AM
Chad29860's Avatar
Your gonna have to get a tuner and have it deleted. I would say call innovative and get ya an SCT with some mild tunes for now if your not studded
Chad
35" Mickey Thompson MTZ's
4" MBRP Turbo back exhaust with miter cut stacks
Sinister EGR delete
ARP Studs and oil cooler rebuild
DieselSite Turbo Boots
DieselSite Coolant filter kit
Stage 3 Tranny kit with Billet Dual Disc TC
Chad29860 is offline
post #4 of 19 Old 05-06-2012, 07:28 AM
Brief stints over a 110 aren't going to cause a tire to suddenly explode. It'd be nice when I'm passing semi's to go over 95 cause 90% of the time I'm sitting on the speed limiter before I'm done passing and that's never a good feeling.
2011 6.7 FX4 Lariat
TheBoss is offline
post #5 of 19 Old 05-06-2012, 12:58 PM Thread Starter
Will the 6.7 not hold or why should I head stud a brand new truck? You have to wonder why you could not pay the dealer and sign a waiver to get this removed.
post #6 of 19 Old 05-07-2012, 06:39 AM
Term3's Avatar
Because its illegal for the dealer to remove the speed limiter. Leaves them wide open for liability law suit.
Term3 is offline
post #7 of 19 Old 05-07-2012, 06:46 AM
Term3's Avatar
Agreed, I have the speed limiter removed on my Ex. I do have tire pressure sensors installed which also display temperature and the temperature rise rate is scary at those speeds.
Term3 is offline
post #8 of 19 Old 12-23-2012, 08:42 PM
Everybody knows if you go over 95, you go back to the future. Duh! Wait that was 85 mph.
Silverspank is offline
post #9 of 19 Old 12-23-2012, 09:07 PM
I used my H&S mini maxx to lower mine to 87mph.
09XLT is offline
post #10 of 19 Old 12-23-2012, 11:18 PM
The admin key does that too!
MR. EVO MR is offline
