Why can diesels idle forever? - Ford Powerstroke Diesel Forum
post #1 of 43 Old 04-30-2012, 08:44 AM Thread Starter
TX_TRU_STUD's Avatar
Quoted: 52 Post(s)
So I've known that guys with diesels let their trucks idle all day out on ranches and job sites and stuff. Is there a reason they do this as opposed to gassers? I think it's cool but I would imagine it uses a lot of fuel.
TX_TRU_STUD is offline
post #2 of 43 Old 04-30-2012, 08:59 AM
Quoted: 364 Post(s)
Feedback Score: 5 reviews
Because for diesels its better to idle then get shut down for short stops...
Edit: you said all day long... That is MOST of the time un-needed... Unless the truck is powering some equipment...
Also... I don't care who you are...try ideling a 6oh w/o the high idle mod done with its variable vane turbo
Sent from my crazy phone that posts behind my back...
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is online now
post #3 of 43 Old 04-30-2012, 09:01 AM
dieselmatt's Avatar
Quoted: 4 Post(s)
This thread should get some interesting answers.
Subbed.
dieselmatt is offline
post #4 of 43 Old 04-30-2012, 09:04 AM
elm302's Avatar
Feedback Score: 3 reviews
I think its hard on em unless there idled up. They can wet stack easier when idling.
2003 F350 Lariet Leveling kit eagle 197s MBRP stainless tb to 6" stack Sinister coolant kit Sct with Looney and Innovative High Idle fog light and bright box mod soon to come Edge CTS PHP ficm tuning and Cab lights
elm302 is offline
post #5 of 43 Old 04-30-2012, 10:29 AM Thread Starter
Quoted: 52 Post(s)
So I was a little loose with my term on "all day". I should have said a good while, say 30 min or an hour (plus or minus some time).
We had a guy come out this weekend and he left his truck running for a good 30 minutes while we went into the back of our property and looked at some things. I would have turned my truck off but it's not diesel.
So I guess my question is, how long should you leave it running before you should turn it off? whats the break even point?
Also, I have not seen a high idle option on the new super duties, but it has been a month or so since I have looked at all the options. Do the 6.7's need it?
post #6 of 43 Old 04-30-2012, 10:32 AM
Quoted: 364 Post(s)
The need for cooling the turbo requires a minute or two..... 30 minutes is too much but to each his own I guess
Studded and Deleted
post #7 of 43 Old 04-30-2012, 11:03 AM
TheFordman87's Avatar
Lots of idle time clogs the egr valve over an extended period of time. But a diesel needs a high idle mod to run every now and then if your keeping the truck idling all day. If you have equipment your running on the truck it's obvious why your letting the truck idle.
Btw a hgh idle mod is something you do yourself. I haven't heard of a truck coming with it from the factory.
I'm addicted to diesel and I step on it constantly!
TheFordman87 is offline
post #8 of 43 Old 04-30-2012, 11:05 AM Thread Starter
Quoted: 52 Post(s)
Chevy has a high idle switch option on their 2500hd. Maybe this link will work...
Chevrolet | Build Your Own - Customize Your Perfect Car By Trim
post #9 of 43 Old 04-30-2012, 11:09 AM
I should have specified that idk anything about Chevy I thought we were talking about ford here. Sorry
post #10 of 43 Old 04-30-2012, 07:43 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
our trucks idle a bunch. when putting the plows on and warming up and taking a nap or whatever. 04 6.0, stock everything, not a single issue with egr components or anything due to prolonged idle. our 2005 f350 we just sold had stock egr valve for 60k miles and idled alot no issues then deleted the egr and other preventative maintenance just to be safe. our 2010 has had 0 issues and i just tuned it and loving the power, debating egr delete. just got our 6.7 2 weeks ago so no info on idling yet.
i do not use high idle switches, the trucks idle up on their own and have that im guessing built into their tunes. plus when you start it in cold weather you shouldnt throw it on high idle right after you start it so what are you gonna walk out into the snow in 2 minutes again and throw the high idle on. i sure dont. I let the trucks do their thing and have had 0 issues. although our trucks are meticulously maintained which is a huge factor in how it runs i believe. i know like big rigs they let them idle instead of shutting them off because of different reasons i believe. I could imagine that the pro longed idle with dpf equipped trucks is hard because of the dpf but i believe if the truck goes into regen while in park it goes all the way to 2100rpms
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
