TPMS light on - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-26-2012, 10:05 PM Thread Starter
PhatF350's Avatar
TPMS light on
after changing my tires & rims to 37 13.50 20 after driving about twenty miles my light turns on. I do not what to do to get it off again any infomation would be helpfull
PhatF350 is offline
post #2 of 10 Old 04-26-2012, 10:11 PM
cweiss87's Avatar
Take it back to the tire shop. Probably one of your sensors.
04
F-250 FX4.
Sct X2 with tunes from Gearhead
Zoodad mod
High idle mod
Straight pipe exhaust
BDS leveling kit
Stage 1 intake
cweiss87 is offline
post #3 of 10 Old 04-26-2012, 10:16 PM Thread Starter
PhatF350's Avatar
he said because the tires I put on were 65 psi max and the tires i took off were 80 psi ? I'm wanting to find out if that statement is true Thanks for your help
PhatF350 is offline
post #4 of 10 Old 04-27-2012, 03:32 AM
bltp203's Avatar
Well its the pressure you are running.......not the tires. If you are running your tires at 65 psi, then you should be within the preset tolerance. If you are running lower then that, then yes you will throw a warning.
2012 F-350 CCSB 4X4, plow package, Skyjacker 1" leveling kit, 295/70/18 Nitto's
bltp203 is offline
post #5 of 10 Old 04-27-2012, 04:07 AM
and
quote changing my tires & rims close quote
I would vote with new stems the TMPS units are now missing thus nothing for the system to read the tire pressure thus the light
TGIF
DieselFord is offline
post #6 of 10 Old 04-27-2012, 07:21 AM
cweiss87's Avatar
A good tire shop would get new bands for the bigger rims and keep the sensors on so you wouldn't have a light on. But I do agree that could be what happened. If they are there just find out what the system is set for so you know if it needs reprogrammed for a lower pressure
04
F-250 FX4.
Zoodad mod
High idle mod
BDS leveling kit
Stage 1 intake
cweiss87 is offline
post #7 of 10 Old 04-27-2012, 07:27 AM
Ranger429's Avatar
^^ This.
Also when I put the 35's on my 12 the dealer reprogrammed the TPMS computer for the corrected air pressure.
Ranger429 is offline
post #8 of 10 Old 04-27-2012, 06:45 PM Thread Starter
PhatF350's Avatar
Thanks you guys are the best, Thank you all for your help. The lift shop that lifted my truck drilled out my spare mounted all the sensors in the spare ?
I will be talking with him next week to put the sensors back in each tire, retrain the computor, air to max tire pressure @ 65 psi take it to the dealer to lower my TPMS setting.
Do you think that is the cure
PhatF350 is offline
post #9 of 10 Old 04-27-2012, 08:17 PM
Alberta Advantage's Avatar
Quoted: 19 Post(s)
The dealer can relearn the TPMS sensors by doing a key cycle and then using the remote to save the current PSI information. I'd just get the shop that removed them to put them back in and then go to your local dealership and get them to relearn the sensors/TPMS to the operating spec of your aftermarket tires so they work like they should and operate how they would if you had the stock tires on.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #10 of 10 Old 04-27-2012, 09:52 PM
Sensors in the spare will not work.
Retraining the sensors with the reset tool will do nothing to set them to a lower pressure, the TPMS module in the vehicle will still be calibrated for 65 front 80 rear.
You CAN on the 2011/12's set the module to a lower pressure using an IDS scan tool. Not all dealerships will as we are not really supposed to.
1991 Ranger - 38" TSL's, 3 link, One tons, 5.38s on King air shocks....under construction.
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 31x10.50r15 MT's.
2008 F350 - Crewcab short bed, 6.4L diesel, H&S XRT Pro, AFE DOC/DPF delete
1972 Mustang Coupe - 302, c4, 9", 4.11's locked.
WildStyle is offline
