Oil Temperature - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-15-2012, 08:57 PM Thread Starter
Oil Temperature
Did my first tow of the fiver through the mountains this weekend and saw oil temps going up to 238 degrees. Most of the time it sayed around 210 +/- few degrees, but when pulling up mountain it would go up. Never had a cooling fan come on as most gages stayed around the same. Is this normal oil temp when towing and what temps does a cooling fan come on?
travlingman is offline
post #2 of 4 Old 04-16-2012, 09:24 AM
mor4wd's Avatar
My fan typically comes on at about 240. The oil temps get pretty hot on these trucks when towing, I've seen 249 before but have never had a problem. My H&S MiniMaxx gives me a high coolant temperature warning but the truck never faults.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #3 of 4 Old 04-17-2012, 02:02 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 4 Old 04-17-2012, 11:00 AM
Quoted: 15 Post(s)
Last summer towing equipment up over Logan Canyon to Bear Lake I often saw temps in the 242 range. We asked the Ford Customer Service Rep over on another Forum about it and he checked with the engineers who said that was still in the acceptable range for oil temps.
So I wouldn't worry about the temps you are seeing, The computer takes those temps in consideration when it calculates your oil service life. You are basically pushing it into the Severe Service schedule. And you will see the message to change your oil at shorter intervals than guys running around empty and at lower oil temps.
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
