HELP!! no boost - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-01-2012, 02:30 PM Thread Starter
HELP!! no boost
what could it be ???
tx 250 is offline
post #2 of 6 Old 04-01-2012, 03:01 PM
Blown intercooler boot, blown turbo, or blown line to the gauge.
2011 6.7 FX4 Lariat
TheBoss is offline
post #3 of 6 Old 04-01-2012, 03:07 PM Thread Starter
If it were turbo, i would think truck would not run? Truck does run but not get faster than 30 mph or so and blows black smoke from exhaust. I checked hoses, is there a diagram of all hoses having to do w turbo, intercooler etc?
tx 250 is offline
post #4 of 6 Old 04-01-2012, 06:19 PM
Depends on how the turbo blows. Sounds like an intercooler boot.
2011 6.7 FX4 Lariat
TheBoss is offline
post #5 of 6 Old 04-01-2012, 07:37 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 6 Old 04-02-2012, 08:19 AM
Summitman's Avatar
Yep, sounds like a cut boot or a tube blew off. Recheck all the boots, I've seen them get a long hair line crack that you can't see, you could only find it after you put your hand on every boot.
Summitman is offline
