DEF filler - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-26-2012, 06:26 PM Thread Starter
DEF filler
I got an education today at the truck stop. (I picked a time when they weren't to busy) I tried to fill my DEF tank from the bulk tank - got about 10cents worth each time I squeezed the handle. Finally gave up and tried a different pump, same thing. Gave up all together and went inside and asked about it. Said they had to authorize it. So went back out and tried again and same thing, then she said to come back in and borrow their adapter. I finally got a proper fill rate of the tank with the adapter. Here's the only link I've been able to find of the adapter:
DEF adapter
Does anyone know of any other places that have one for less $$$$ ?
2012 F250 CCSB w/Nav
countrylife is offline
post #2 of 5 Old 03-27-2012, 07:23 AM
Try a different truck stop. I used two different Pilot bulk pumps and they worked fine, without an adapter.
I did have a problem with my bank for my debit card though. When I tried to authorize from the pump it would get declined, so I ended up just giving a cash deposit at the register, pumping, and then getting my change back.
I had to tell my bank that I wanted to authorize "DEF" when pumping fuel. Pretty stupid if you ask me, but I guess they're trying to keep me safe from identity theft.
←snow∞motion→ is offline
post #3 of 5 Old 04-10-2012, 06:01 PM
UpToNoGood's Avatar
DEF adapter
My first fill up was at Pilot with no issues. Second fill up or attempt to fill up. Everything you describe happened to me. I even tried different pumps and never got more then .10 if that. I figured it was their pumps that were defective and so did the maintenance guy that tried to help me.
2012 F250 CC Lariat 4x4 Tricoat White
UpToNoGood is offline
post #4 of 5 Old 04-11-2012, 09:40 AM
Quoted: 18 Post(s)
Some of the pumps have a magnetic sensor on them to make sure the pump is inserted into the tank and has not fallen out. The adapter provides the opposing metal ring for the magnet to sense when ever you fill a plastic jug or if the magnet can not sense the metal of your bed. Our trucks have a plastic filler neck, So the magnet just doesn't sense them.
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #5 of 5 Old 04-12-2012, 07:29 AM Thread Starter
I stopped in at Love's truck stop and they had the adapters for $15. So I got one just-in-case I ever need one.
