Oil life indication? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-25-2012, 06:41 PM Thread Starter
The manual says oil life is dependent on how the vehicle is used. So I went to the on-board display for oil life expecting it to tell me something like 70% remaining or something like that. Instead it says "OK". If I'm getting "close" I'd rather have it done before I leave on a trip than to try to find someone to do it "on the road". Am I missing something? How do I get it to tell me the oil life status?
It's a 2012 Lariat.
countrylife is offline
post #2 of 11 Old 03-26-2012, 04:10 PM
That's all it says. When your close it says Change oil soon. Then if u wait longer it'll say oil change required if I remember correctly
Current Rig: 2011 F-350 CCSB Lariat chrome FX4 Tuxedo Black.
Mods: aFe stage II, 8000k HID. 6" 4link Skyjacker Lift, 37" Toyos Wrapped around 20x9 XD MisFit Rims, H&S Minimaxx, 5" FloPro straight pipe
Traded: 2006 F-350 CCSB Amarillo Edition
Mods: 6" BDS 4-Link Lift Kit, 4" MBRP Cool Duals Exhaust, AFE Intake, Edge CTS Evo, 37x13.5x20 Toyo MT wrapped around XD Spy 20x9 Rims
UA Local 488 Steamfitter/Pipefitter
AlbertaStroker is offline
post #3 of 11 Old 09-09-2014, 10:33 AM
I have read in many forums and manuals and the oh so lovely google, on how to reset the oil life, I have the 3 button system on my 2010 F250 and when i cycle through the system setup bit, it goes to engine hours and cycles through a very slim number of items, none of which say anything about oil and its life - am i missing something, or is there a chance that there is a programming chip to disable that notifier and previous owner did that, or am i really as stupid as i look.
peripheralthinker is offline
post #4 of 11 Old 09-09-2014, 10:38 AM
TX_TRU_STUD's Avatar
Quoted: 52 Post(s)
yes it will say soon and then say required about 500 miles later.
TX_TRU_STUD is offline
post #5 of 11 Old 09-09-2014, 10:49 AM
Quoted: 18 Post(s)
Also, when I turn the key on, right about the time i go to actually crank the truck, an oil can kinda flashes on the information center....ids that normal or is it telling me that i need to give something a lil TLC
Can't speak for the 2010 with the 6.4L engine. But on the 2011 with the 6.7L It's in your command center
As far as the quick blink Oil Can on the screen. As the system does it system check, It's flashing that you have no oil pressure. Which is normal, since you have not started the engine at that point. As soon as the engine starts youy have oil pressure and the oil can goes away. So totally normal
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #6 of 11 Old 09-09-2014, 11:07 AM
Thank you for the answer on the pressure can....after i posted that part, i found the answer....i always manage to struggle to find an answer to something and then when i finally ask on the forum, i miraculously find the answer somewhere before i get a response, lol.....but im still confused with the reset of oil life, it is not in my comm center, or im just not knowing what im doing...
post #7 of 11 Old 09-09-2014, 12:05 PM
Quoted: 83 Post(s)
6.2L gas Trucks got the % oil life left. Diesels only show OK.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #8 of 11 Old 09-09-2014, 12:15 PM
my 6.4 diesel says nothing pertaining to oil....just the oil can flash before ignition on...nothing in the info center otherwise
post #9 of 11 Old 09-09-2014, 03:23 PM
bigblzr94's Avatar
Quoted: 4 Post(s)
if you have the sync system and do the vehicle heath report it will give you the % remaining
2014 F-250 Platinum Kodiak Brown (1st Ford ever, and loving it, thanks for nothing GM)
2014 Chevy "Shakearado" POS traded to Ford after 3 months
1999 GMC Suburban k2500 454 (gas hog)
1994 Chevy Blazer 2 door (dog truck)
1997 Chevy C1500 Prerunner (toy)
bigblzr94 is offline
post #10 of 11 Old 09-09-2014, 03:36 PM
Quoted: 279 Post(s)
As stated, it will tell you with approximately 500 miles left till "change oil required" appears. On my Explorer, I get it at the 5% left mark which we are close to 10,000 mile changes so that matches up with the 500 mile +/-.
Obviously cycles and driving habits can vary between people but figure the warning comes up at the 5% left mark.
15 6.7 F350 CCSB 4x4 Platinum Bronze Fire
Husky mats, all LED interior, Nushield for MFT, Bakflip F1 with Bakbox 2, Dieselsite fuel filter, DeeZee tailgate assist, Hellwig Rear Sway bar, Bilstein 5100s
**Support the Online Vendors!!! Want your best price, buy from Scott Pratt!! Get your truck in 3-4 weeks, order to delivered!!
blwnsmoke is offline
