Fass/Air dog/Dahl 150 - Ford Powerstroke Diesel Forum
post #1 of 29 Old 03-06-2012, 01:54 PM Thread Starter
hw713713's Avatar
Ok here is what I am thinking. Let me know if you think this will work. I am not wanting to do any aftermarket performance work on this truck. But I have been doing to much Internet research and I think I have scared myself into cleaning up my fuel. I have been looking into the fass system but the information is just not there as far as instruction manuals and what not. ( I have ran both on previous trucks and the only difference I notice is the noise level). I am thinking of running the AD II 100 as well as in conjunction with the DAHL 150 and both factory fuel filters. The concerns I have are as follows.
1) will the AD be able to push the fuel the truck needs through all filter devices. ( thinking about putting the Dahl 150 on the return side of the AD? )
2) is this much filtration needed?
3) any chances of not catching the water with this set up?
4) Anyone installed one of the AD's yet. I wanna figure out a way to get quick connects and not damage any factory lines in the event that I have to take it into the dealer I can remove everything and put it back to factory. Any advice would be great.
Thanks,
Sent from my Autoguide iPad app
2012 F250 KR, H&S mini max, full delete, Carli 2.5" pin top w/full replacement leafs, S&B intake, ADII and a camper shell!!!!
2013 Touareg TDi (mommas ride) She won't let me touch it.
hw713713 is offline
post #2 of 29 Old 03-06-2012, 08:20 PM
bltp203's Avatar
So if I am reading this correctly, your plan (at this point) is to push the fuel through 3 sets of filters?
2012 F-350 CCSB 4X4, plow package, Skyjacker 1" leveling kit, 295/70/18 Nitto's
bltp203 is offline
post #3 of 29 Old 03-07-2012, 04:59 AM Thread Starter
hw713713's Avatar
Well kinda. The air dog filter / water separator, ford water separator, ford filter. Then on the return side of the air dog also run a Dahl 150 water separator.
hw713713 is offline
post #4 of 29 Old 03-07-2012, 05:10 AM
matty21's Avatar
Why? The ford filters are good enough to keep you warrantee intact according to ford.
And you won't be pushing more flow so what's the point. Sounds like overkill paranoia
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #5 of 29 Old 03-07-2012, 06:25 AM Thread Starter
hw713713's Avatar
I agree but reading about the HPFP failures and ford not covering it due to water in fuel it has me concerned. Especially at the risk of a 10,000+ repair bill. Just nervous.
hw713713 is offline
post #6 of 29 Old 03-07-2012, 08:15 AM
I took delivery of my brand new 6.7L 2012 F-350 right before Christmas. Had AirDog II system installed 3 days later. All is still good after 3000 miles. Everything else is factory stock (except my Bilstein 5160s )
I'm also adding Stanadyne Purple to every tank.
I sleep good at night.
AEST BOSS is offline
post #7 of 29 Old 03-07-2012, 08:42 AM
matty21's Avatar
Your parinoid, I have almost 65k , never drained the water until last week when the light came on but was due to broken sensor, and there was no water in the fuel. and had my filters changed once At 30~k. No issues. I think the hpfp issues are few and far between and likely due too poor maintenance and/ or fuel quality.
Yet to be delivered
AFE stage 2 intake
matty21 is offline
post #8 of 29 Old 03-07-2012, 10:17 AM
camdenlake's Avatar
Quoted: 15 Post(s)
I too was once super paranoid. But i have come to the same conculsion after reading hundreds and pages and doing research locally.
Sweet truck by the way Matty21.
Josh
1999 F150 4x4 With the not so stock V10
2009 Shelby GT500 - Grabber Orange
2012 F350 6.7 CC SB FX4 - Sold
2015 Explorer Sport - Black on Black - Sold
camdenlake is offline
post #9 of 29 Old 03-07-2012, 01:14 PM
bltp203's Avatar
Plus, who is to say that Ford won't deny a warrant for a fuel system issue once they see an aftermarket fuel delivery system hooked to the framerail.
bltp203 is offline
post #10 of 29 Old 03-07-2012, 02:40 PM Thread Starter
hw713713's Avatar
Do you know if they made any internal fuel tank adjustments on installation? If I am reding the instructions right it is a simple quick connect. On all the dodges I installed them on you had to drill holes in the pick up cup on the factory set up.
hw713713 is offline
