Fuel/water seperater?? - Ford Powerstroke Diesel Forum
post #1 of 24 Old 02-25-2012, 10:23 AM Thread Starter
matty21's Avatar
I know this has been discussed before , and for that i apologize , but I can't find the thread again and i lost my manual . Where is it located and how do I do it? My water in fuel light has been on for over a month now , and I want to do it.
Thanks
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #2 of 24 Old 02-25-2012, 10:26 AM
Chug-a-lug!!!
colberjs's Avatar
Quoted: 10 Post(s)
It is inside the frame rail kind of underneath the drivers door. It has a yellow knob on it.
Jesse
2011 F-250 Fx4 CrewCab Short Bed
Bone Stock............Or Is It?
colberjs is offline
post #3 of 24 Old 02-25-2012, 11:10 AM Thread Starter
matty21's Avatar
For how long? Till it stops like the 6.4
Yet to be delivered
AFE stage 2 intake
matty21 is offline
post #4 of 24 Old 02-25-2012, 11:48 AM
Chug-a-lug!!!
colberjs's Avatar
Quoted: 10 Post(s)
I don't think it will stop. Just until the diesel is running clean and there is no water or trash in it.
Jesse
colberjs is offline
post #5 of 24 Old 02-25-2012, 11:58 AM
CascadeF250's Avatar
Smile
Thanks
. If I remember correctly you open the yellow drain knob until the O ring is showing and drain for 25 seconds. I have never seen water in my fuel. I drain into a jar and let it sit overnight.
CascadeF250 is offline
post #6 of 24 Old 02-25-2012, 11:59 AM
Senderofan's Avatar
Matt:
I think if you open it for a couple of seconds.....it should do it. Looks like the bowl holds 1/2 to 3/4 cups of ljquid. Might also be a good time to change the filter if you haven't done that yet...imho.
2011 F 350 Lariat Ultimate CC, SB 4x4 with 6.7 PowerStroke. Sterling Grey Metallic. Stock rims, tires. Shocks are Bilstein 5160's...what an upgrade over stock!
2013 PW Boss Mustang with aftermarket fully adjustable suspension, Team Dynamic 18"x10" race wheels and 305mm Continental race slicks at all four corners....O/R X pipe, 84.5mm TB, Airaid cai, 47 lb injectors...tuned by AED...Life is fun in this vehicle!
Senderofan is offline
post #7 of 24 Old 02-25-2012, 01:50 PM Thread Starter
matty21's Avatar
thanks guys.
i did it and it drained full flow so i left it about a minute,. it looked clear all along, so i closed it up, then the light came on again after an hour of driving. should i do it again? or is there a reset
also i changed the filter only 2000km ago, so.......?
Yet to be delivered
AFE stage 2 intake
matty21 is offline
post #8 of 24 Old 02-25-2012, 03:03 PM
Scubamax's Avatar
In my experiences with making bio diesel, it should be pretty easy to see water in the fuel. I like the idea of draining it in a jar, if water is present, you should be able to see it after only a few min if it's not emulsified. If it is emulsified, we would drop some bio on a frying pan(hot plate) and if it popped, it had water(there's a little more to it than that, but its the short version) And, you should only have to drain about a quart or so. You only need to drain out what is in the "cup" if there really is water. The only reason I'm bringing this up is because I've heard this question being asked several times. I hope your water in fuel light is acting up. I walk on the bad side of town at midnight on a saturday night without fear, but water in fuel scares the hell out of me!
Scubamax is offline
post #9 of 24 Old 02-25-2012, 04:05 PM
Chug-a-lug!!!
colberjs's Avatar
Quoted: 10 Post(s)
All the horror stories I have heard about Ford not warrantying thousands of dollars worth of engine repairs because of poor fuel quality scares the crap out of me too. From what I have heard, as soon as the water in fuel light comes on Ford wants you to kill the truck immediately and have it towed to a dealer.
Not sure how many miles you have on your truck but I do know you have a lot of aftermarket go-fast parts so it may not matter one way or another.
Jesse
colberjs is offline
post #10 of 24 Old 02-25-2012, 04:18 PM
Senderofan's Avatar
Matt:
I think you must have gotten a bad tank of fuel. For the light to come on again...I wouldn't want to risk ruining the fuel system...being they seem to be so sensitive to water contamination. To drain the unit for a full minute...must have been a significant amount of fuel you got out.
Wayne
