Break In Attempt - Ford Powerstroke Diesel Forum
post #1 of 12 Old 02-24-2012, 08:26 AM Thread Starter
jeepraptor's Avatar
Break In Attempt
Luckily they didn't get in but still a hassle! Anyone know how much handles are costing these days?
ID:	34456   Click image for larger version
jeepraptor is offline
post #2 of 12 Old 02-24-2012, 04:03 PM
srjd's Avatar
Quoted: 2 Post(s)
Mine got broken into and had to replace the lock and the handle had to be painted to match it was around 300 bucks
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #3 of 12 Old 02-24-2012, 04:59 PM
Scubamax's Avatar
That sucks!
Scubamax is offline
post #4 of 12 Old 02-24-2012, 06:35 PM
I took my locks out and rods out of my doors. Used the jimmer jammer plates and lock plugs. I figure if they punch out the door they will not find the rods either. Now the only way in is break the window without using keyless entry or key fob
olds403 is offline
post #5 of 12 Old 02-25-2012, 05:02 AM
AMEC Electric's Avatar
Great idea! Do you have pics of the plugs installed?
AMEC Electric is offline
post #6 of 12 Old 02-25-2012, 05:06 AM
Scubamax's Avatar
I would LOVE to disconnect the rods from my door, but, I guess I'm too chicken. If the battery goes dead, your screwed! My truck stays parked in my garage, so my battery is more likely to go dead than someone breaking into it. I will install the jimmy jammers though. It really sucks that there are low life's out there that won't work for there own stuff.
Scubamax is offline
post #7 of 12 Old 02-25-2012, 06:06 AM
The photos of this setup are actually on the jimmy jammer website its called a punch plug. I got all the parts from az trucks. You will need to call them.
As for the dead battery concern, i don't loose sleep over it. On all my other trucks, the doors would open, but starter would not turn over the motor when the battery was dead.
My wife thought i was nuts taking a brand new truck apart and i must admit that taking the door panels apart made me nervous, buts its real easy. While i was there i slipped in some new front door speakers.
The whole setup took me about 3hrs to do on all the doors. One piece of caution is to have a helper nearby when you take the last bolt out of the outside door handle as i dropped mine on the driveway which scratched it some.
Overall peice of mind....
olds403 is offline
post #8 of 12 Old 02-25-2012, 06:21 AM Thread Starter
jeepraptor's Avatar
Has anyone put on a rear door handle that has no key hole?
post #9 of 12 Old 02-25-2012, 06:25 AM
baddkarmaracing's Avatar
Quoted: 3 Post(s)
Not a 6.7 but my 6.4 has rear handles all the way around
2008 F250 6.4 CC SB Fx4
Gearhead tunes, flopro exhaust,AFe intake
baddkarmaracing is offline
post #10 of 12 Old 02-25-2012, 06:43 AM
Slacker
Evil Eye's Avatar
Quoted: 226 Post(s)
Feedback Score: 4 reviews
Sorry to hear that especially on a brand new truck! That's happened to mine as well. I still haven't replaced the door handle, so I'm hoping that someone has part numbers or info for the back handles.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
