Special Service Message PO181-Fuel Temp. Sensor - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-22-2012, 06:06 PM Thread Starter
gryzula40's Avatar
Three weeks ago I went to dealer with engine light on problem. Ford told me is was fuel temp. sensor which they replaced. Since then every night I was using my block heater, yesterday engine light came on again. Today went to same dealer they diagnosed same problem (fuel temp. sensor) and dealer was told by Ford not to fix the problem until farther notice. Dealer gave me note from Ford saying:
Effective date 02/22/2012
22227 6.7L-Diagnostic trouble code (DTC) P0181 when using block heater
Some 2011-2012 F-Super duty vehicles equipped with a 6.7 diesel engine may exhibit DTC P0181 when customers use the block heater. Do not attempt to repair this concern by replacing the fuel rail temperature sensor (9F951). Tis concern is currently under engineering investigation.
Is anybody else having this problem
2011 F350 King Ranch - Tuff Country 2.5" leveling kit - 20x9 KMC XD Crank chrome wheels with 35x12.5x20 Nitto Trail Grappler - 50 gal. Titan fuel tank - S & B air intake kit - Pace Edwards Full Metal Jack Rabbit Tonneau Cover - Retro Solutions head and fog lights 55W HID kit - Viair 100% duty air compressor,5 gal. air tank and train horn - Weather Tech floor liners and mudflaps - AMP Reserch bed extender - H & S Black Maxx.
gryzula40 is offline
post #2 of 7 Old 02-22-2012, 06:14 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Is it saying the temp is too high or too low? Or that the sensor itself it bad?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 7 Old 02-22-2012, 06:32 PM Thread Starter
gryzula40's Avatar
I think the sensor is bad, dealer sad they can't change the sensor for second time and is ok to drive.
post #4 of 7 Old 02-22-2012, 08:07 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 7 Old 02-22-2012, 10:33 PM
Pretty much our hands are tied until engineering comes out with an updated fix.
1991 Ranger - 38" TSL's, 3 link, One tons, 5.38s on King air shocks....under construction.
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 31x10.50r15 MT's.
2008 F350 - Crewcab short bed, 6.4L diesel, H&S XRT Pro, AFE DOC/DPF delete
1972 Mustang Coupe - 302, c4, 9", 4.11's locked.
WildStyle is offline
post #6 of 7 Old 12-18-2013, 11:20 AM
justindacey's Avatar
Anyone ever get an update on this? My '12 just threw this code twice this week. It was very very cold both times...
2012 F250 CCSB 6.7 20's, BFG AT's, 3.5" Readylift
SOLD 2008 F250 6.4 SCSB Minimaxx w/ HD 300, 4" FloPro, Alpine touchscreen
justindacey is offline
post #7 of 7 Old 12-18-2013, 11:30 AM
dperone's Avatar
Quoted: 5 Post(s)
I know Chevy's with a Duramax engine have the same problem, if they are plugged in when the temps are above 0 degrees I believe, they set the same code. According to the TSB, it has to do with a difference in the fuel temp sensor and the intake air temp sensor I believe. It's been a while since I've read the TSB, but I remember it had to do with the block heater warming the engine and the fuel temp being out of range with the other temps that were warmed by the block heater. I would imagine the Ford's could have the same issue, but I haven't heard of them yet, and I usually don't plug mine in. Hope this helps.
dperone is offline
