Has anyone tried rims with a +30mm backspacing? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-20-2012, 07:05 PM Thread Starter
I found some 22 inch rims that i really like, but they have a 30 mm backspacing just wondering if they will work. I have a 2011 250 king ranch... any input is appreciated
tzeman2 is offline
post #2 of 7 Old 02-20-2012, 07:12 PM
They will be tucked in quite a bit. If you want them to stick out some then you need like +15 to +20 If you get to -numbers they will stick out a ton. Like American forces are -25 I think
4EverBoosted1 is offline
post #3 of 7 Old 02-20-2012, 07:26 PM Thread Starter
im fine with them being tucked in as long as they don't rub
tzeman2 is offline
post #4 of 7 Old 02-20-2012, 07:33 PM
Cool
It all depends on tire size
post #5 of 7 Old 02-20-2012, 07:40 PM Thread Starter
yeah im thinking 305/45/22. will be about the same height as stock, but should be a bit wider
tzeman2 is offline
post #6 of 7 Old 02-21-2012, 02:46 AM
matty21's Avatar
You can always get spacers . If they do rub
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #7 of 7 Old 02-21-2012, 11:37 PM
vlxjim's Avatar
If they are 10" or greater they could rub. Stock 20's are 8.5" and +40mm offset. I know 9" +20mm works. So it could be close.
2011 F250 PowerStroke CCSB Lariat FX4 Loaded | Icon 2.5" Stage 2 | Icon track bar | Top Gun Dual Stabilizers | 20" Fuel Boost wheels +1 offset | 325-60-20 Hankook Dynapro ATm | RBP RX3 steps | BakFlip F1 Bed Cover | All Sales Mfg Fuel Door | Randy Ellis Light Bar | Hella Lights | aFe Magnum FLOW Pro-GUARD 7 Air Filter |
vlxjim is offline
