Changed to mobil 1 5-40 turbo diesel oil-Loss of MPG and now have a knock - Ford Powerstroke Diesel Forum
post #1 of 26 Old 11-25-2011, 01:59 PM Thread Starter
First 6.7 PS Destroyer
mysticblu999's Avatar
Quoted: 2 Post(s)
Just switched to Mobil 1 5w-40 turbo diesel full syn oil the other day. I swear I have lost almost 2mpg with it. Now everytime I let it idle, I can hear a knock or the typewriter noise. I can even hear it while driving slow and there is somthing around to echo off of. I have always wanted to try this oil out. Can't believe the difference this is. I can't bring myself to drain the oil yet.
Ive got $150 in this oil change, so ill just wait a little longer. Can't wait to switch back to Motorcraft 10-30. Anyone else have this happen? I know I've heard of people talking about the knock after an oil change but don't know what oil was used. Truck has 26k on it.
2011 F250 6.7 4x4 CC Lariat
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
5" MBRP straight pipe
AMP Steps
Truck pics ---->
mysticblu999 is offline
post #2 of 26 Old 11-25-2011, 02:03 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
I was tempted to do the samething and switch, but I change my oil every 5K miles so I stuck with Motorcraft 10-30. Sounds like I made the right call! BTW, No typewriter noise as some on here have complained about.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 26 Old 11-25-2011, 02:04 PM
Strange that it caused that. I ran the same oil in my 6.0 for 2 years no issues. Hopefully you don't blowup another 6.7 mystic lol
Current Rig: 2011 F-350 CCSB Lariat chrome FX4 Tuxedo Black.
Mods: aFe stage II, 8000k HID. 6" 4link Skyjacker Lift, 37" Toyos Wrapped around 20x9 XD MisFit Rims, H&S Minimaxx, 5" FloPro straight pipe
Traded: 2006 F-350 CCSB Amarillo Edition
Mods: 6" BDS 4-Link Lift Kit, 4" MBRP Cool Duals Exhaust, AFE Intake, Edge CTS Evo, 37x13.5x20 Toyo MT wrapped around XD Spy 20x9 Rims
UA Local 488 Steamfitter/Pipefitter
AlbertaStroker is offline
post #4 of 26 Old 11-25-2011, 02:07 PM
Quoted: 4 Post(s)
Another??? Yikes, this could get expensive! Hopefully, it wasn't the same reason.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #5 of 26 Old 11-25-2011, 02:16 PM Thread Starter
Quoted: 2 Post(s)
Alberta stroker, I know man, I am a big mobil 1 fan, I love their oil. I've always condsidered it to be among the best. Maybe the new engine doesn't like it as much as the 10-30 motorcraft, anyway thats what will be going back in it.
Stroker8, here is some good reading for you, if you haven't seen this thread before, this was posted while it blew up.
http://www.powerstroke.org/forum/6-7...ing-broke.html
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
AMP Steps
Truck pics ---->
post #6 of 26 Old 11-25-2011, 02:25 PM
Quoted: 4 Post(s)
Wow, that was just bad luck!
Hopefully, the same won't happen this time around.
Getting back to the knocking, I wonder if you have to add the same amount when using Syn??? I know it shouldn't matter right but I have heard in some cases where not putting in as much as conventional oil fixes this problem?
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #7 of 26 Old 11-25-2011, 02:39 PM
tjbrowder's Avatar
Running Rotella T6 5W40 synthetic....no noises to this point, and no loss in mileage.
2011 F450 CC/LB 4X4
2010 F250 CC/SB FX4 *SOLD*
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website (Powerstroke.org or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my truck, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
tjbrowder is offline
post #8 of 26 Old 11-25-2011, 02:57 PM Thread Starter
Quoted: 2 Post(s)
Rotella is my other favorite, I run it in my turbo bike, dirt bike and track bike. Great oil. I'm gonna check the oil again in the truck in a few. 5 mins after I got home I checked it, it was right up on the min line.
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
AMP Steps
Truck pics ---->
post #9 of 26 Old 11-25-2011, 06:21 PM
mor4wd's Avatar
I'm wondering if it wasn't more the switch to a different weight more than the switch to synthetic. I'm posting this article to spread a little info. There's a lot of preference's in oils, one claiming to better than the other and such. This article by Blackstone Labs breaks it down. This is also why I don't waste money on expensive oils, like Amsoil or Royal Purple. I buy Motorcraft or Rotella because it's typically the cheapest. Regardless, it's a good read.
http://www.blackstone-labs.com/Newsl...ril-1-2010.php
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #10 of 26 Old 11-25-2011, 07:39 PM
tjbrowder's Avatar
Agree....Mobil's TD 5W40 is an excellent oil as well.
What you are seeing is most likely due to the change in viscosity.
The 5W40 will run thicker at temperature than the 10W30 you had in there.
Where are you located? Is is getting cold? Maybe the diesel you are buying is a winter blend that is robbing you of a couple of mpg. Just a thought.
Since the 5W40 is recommended for severe duty, I don't think you have anything to worry about from an engine protection standpoint.
2011 F450 CC/LB 4X4
