EGR Delete Kit??? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-29-2011, 09:38 PM Thread Starter
EGR Delete Kit???
Wanted to see if someone could shed some light on what a EGR delete Kit is. I am fixing to purchase a 2011 F250 and trying to do some research before I add anything to the truck. I havent had a diesel since 2006 and seems things have changed a little since then.
So why would you want or not want the EGR system? and Im guessing this will flip out the techs when ou go in for warranty work?
Thanks in advance.
matthewdford05 is offline
post #2 of 10 Old 07-29-2011, 10:01 PM
ups 6.0's Avatar
Thanks in advance.
I'm guessing if you do that you won't have any warranty to worry about!
I think the 6.7 motor is warranty for 100,000 mi. right?
2011 F350 Lariat,6.7,3.55, crew cab, FX4, longbed w/custom Reese 5th wheel hitch,white,black leather,moon roof,navigation.
ups 6.0 is offline
post #3 of 10 Old 07-30-2011, 05:10 AM
s8v4o's Avatar
5 year, 60,000 miles miles for the powertrain. That's of course unless you've purchased the extended warranty.
s8v4o is offline
post #4 of 10 Old 07-30-2011, 05:48 AM
mor4wd's Avatar
I believe ups 6.0 is right with the 100,000 mile warranty on the engine. 60,000 on the drivetrain, 36,000 bumper to bumper. If you got rid of the EGR, you'd be getting rid of your all your warranties at the same time. But getting rid of EGR alone will do little to help, you'd want to go with full deletes, DPF DEF CAT SCR and EGR.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #5 of 10 Old 07-30-2011, 06:09 AM
s8v4o's Avatar
Any links to said info? It's that's correct, that's good news!
EDIT - found it http://www.ford.com/trucks/superduty/2011/warranty/
It says 6.4, but there's a link for the 2011 F250
s8v4o is offline
post #6 of 10 Old 07-30-2011, 06:18 AM
mor4wd's Avatar
When I saw your original post you had me second guessing myself. Actually went to my truck and looked. Glad you found it.
mor4wd is offline
post #7 of 10 Old 07-30-2011, 06:46 AM Thread Starter
Thanks for the responses so far.
I guess my question was more along the lines of: Along with a programmer What is the point of the delete kit? More HP? If its not for HP then why void the warranty and remove it?
post #8 of 10 Old 07-30-2011, 09:41 AM
s8v4o's Avatar
Can't really say for certain on the new 6.7. As for the 6.0 and the 6.4, they failed a lot. So that's why most people just deleted them. The new 6.7 has a separate cooling system though for the EGR and a couple of other things. This separate cooling system runs at a cooler temperature than the rest of the normal cooling system. I would imagine with less temps the unit may last. Hopefully someone else can shed more light on the EGR with the 6.7 and if it's worth removing or not.
I'm not as concerned about the EGR as I am the DPF and DOC.
s8v4o is offline
post #9 of 10 Old 08-01-2011, 06:46 AM Thread Starter
Thanks.
Forgive the the stupid question, What is DPF and DOC?
post #10 of 10 Old 08-01-2011, 06:56 AM
mor4wd's Avatar
DPF is Diesel Particulate Filter
DOC is Diesel Oxidation Catalyst (catalytic converter for diesel)
The DPF is like a honeycomb that traps all the soot. Once it gets "full" the system injects raw diesel into the combustion chamber on the exhaust stroke which gets shot downstream into the DPF and starts burning off the soot under extreme heat.
mor4wd is offline
