Oil Change Warning message - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-25-2011, 08:57 AM Thread Starter
OpWildcat19's Avatar
I had my first oil change a couple of months ago at 4700 miles. I now have 7000 on the truck with 1000 of those in 1 trip to TX pulling the toyhauler in 100+ degree weather. Probably 70% of the new miles have been pulling. The dealer sticker after the oil change says 9700 is when I'm due. I'm now getting a change oil message when I start the truck. Am I really due in less than 3000 miles or did they "forget" to reset something after the first oil change.
Jerrod
OpWildcat19 is offline
post #2 of 10 Old 07-25-2011, 09:22 AM
mazsecond's Avatar
Feedback Score: 4 reviews
These 2011 trucks are very smart. They have what Ford calls an intelligent oil life monitoring system in the engine that monitors your driving habits. My dads 2007 Navigator has one too. Basically, it monitors how you drive the truck including how many starts, idle time, towing, hard acceleration, etc. and moniters temps and calculates when the oil should be changed. 5,000 miles is recommended under "normal conditions" but towing, idling, and lots of starting and stopping are not considered normal. My dad doesn't drive much but takes a lot of short trips (maybe 5 miles, lots of cold starting and stopping which is very hard on an engine, same for driving in the city all the time) and his "Change Oil" notification comes on around 3,000 miles. Even if the Ford Dealer tells you you don't need to change the oil, make them change it. The engine knows what it needs and it will add to its life in the end. I change the oil in my 2006 6.0 every 3,000. I do all city driving, lots of hard acceleration and idling at stop lights. I alsi use Shell Rotella T6 Full Synthetic. I haven'y had a single injector problem, turbo problem, or HPOP problem in 50,000 miles. I also add some Prolong Engine Treatment to every oil change. It's expensive but well worth it. $120 for a do it yourself oil change but new turbos and injectors are thousands!! Good luck with that 6.7.
Mike
mazsecond is offline
post #3 of 10 Old 07-25-2011, 09:49 AM
Sirius Rich's Avatar
I bet your dealer did not reset the oil life on the original oil change.
2011 F250 KR, 6.7, SRW, 4x4, FX4, 20", 3.55, ELD
Sirius Rich is offline
post #4 of 10 Old 07-25-2011, 04:22 PM
s8v4o's Avatar
I went to ford to change my oil at 6xxx miles and the guy at the service desk said Fords recommended interval is 10,000 miles.
If it were based on driving conditions then I would have had to get it done a while ago. Very little of my driving is regular. I spend a LOT of time idling and the other time pulling dump trailers.
s8v4o is offline
post #5 of 10 Old 07-25-2011, 05:31 PM
Mtn Trucker's Avatar
You will never hurt your engine by changing the oil every 3,000 miles but you will definitely put a dent in your wallet. My advice is to send an oil sample in to Blackstone labs and get an analysis for $25.
I did that on my 2008 Cummins and found I could easily go to 10,000 miles between oil changes. And that was even factoring in that the Cummins 6.7 adds a fair amount of diesel to the oil because of how the regen works on it. The oil report showed that after 10,000 miles the build up of particulates and the amount of additives that remained in the oil were all well within acceptable limits. And that was using regular 15w-40 diesel oil and filters.
I plan on treating my new 6.7 Ford the same way. I put over 300K on the Cummins with zero issues.
2011 F350 CC SWB 4x4 King Ranch, Green/Gold, 6.7 auto, Factory 5th wheel hitch, Camper Package, 2" lift, Firestone air suspension
Mtn Trucker is offline
post #6 of 10 Old 07-25-2011, 09:35 PM
richc22a's Avatar
awww heck..change the oil, make sure the oil life is rest. Better safe, than sori..sorri...surry..
.better than injector, turbo, other oil related issues...
Driving: 2011 Pale Adobe...F-350 CC 6.7 FX4 3:55-Locking Rear End-Dual Alternators-premium Lariat, moon rf, added wheel flares, 2-tone black base
Picked up 4/29/10 as of 06/20/2012 109,000+miles
richc22a is offline
post #7 of 10 Old 07-26-2011, 05:05 PM
I have had 3 oil changes now and nearing the fourth. Mine has went about 7100-7400 miles between the "Change oil" light comes on. I pull trailers, idle, city driving and occasional long trip empty so I figure that is about right. I changed the 6.0L every 5k but I didn't have the inteli-sensor on it, was just being safe.
2011 F-250 XLT Crew Cab 4x4 - Sold
Hideaway Gooseneck Hitch to pull my Longhorns!
Access TonnoSport Removable Bed Cover
2006 F-250 XLT Crew Cab 4x4 - Traded
Banks 6 Gun Programmer
4" Turbo back exhaust
EGR Delete
jflow730 is offline
post #8 of 10 Old 07-26-2011, 06:37 PM
I Would say they didn't Reset the oil monitor! Your mileage is correct for the monitor to say it's time to change it since you changed it a little early....
Don't worry about it,If it was mine i would put about 5 to 7,000 miles on the oil before each change...
The way i see it most of the time we don't really get the good out of the oil,meaning it still is doing the job even at 10,000 Miles per change,But i like to take care of my motors and feel changen it out no later than 7,000 is a good Thing!
The way i see it you only have the 1,000 miles pulling the Toy hauler on that oil the rest of the driving really isn't hurting the Quality of the oil much,so I would put another say 3,000 miles on it then change it...
Just reset the monitor and keep track of your mileage so you Know when to change it,then Be sure to Reset the monitor at that change and you will be Good to Go!
Lead Foot is offline
post #9 of 10 Old 07-27-2011, 12:47 PM
doczenith1's Avatar
Quoted: 6 Post(s)
Same here. Oil change at 6xxxx miles and 214 hours. Dealer say these engines can go 10,000 between changes but also said that every 200 hours is a better measure than miles for oil change intervals. The sticker they put on my windshield said 15,000 miles / 400 hours.
Al Bedford, P.E.
2011 F350 Lariat, SC, SWB, 6.7L, 4x4, 3.55ELD, FX4, Lariat Int Pkg, 20's - Ordered 10/27/2010; Delivered 12/13/2010
2002 F250 Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. 12/2001 - 12/2010 - SOLD
With spreadsheet open click File then Download if you would like a copy of the spreadsheet.
doczenith1 is offline
post #10 of 10 Old 07-28-2011, 04:19 PM
tjbrowder's Avatar
Did your "change oil message" come on at 4700? I am not clear on this aspect regarding your post.
2011 F450 CC/LB 4X4
2010 F250 CC/SB FX4 *SOLD*
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website (Powerstroke.org or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my truck, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
tjbrowder is offline
