Retro-Solutions HID Help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-14-2011, 05:11 PM Thread Starter
What's up guys? Got a 6.7 that I'm trying to install the HID's from RetroSolutions. The fogs and tails work great. I wired up the Headlights the first time and no lights came on. I smelled an electrical burn and when I touched the back of the bulb on the passenger side it felt like it was on fire. I called RS and they sent a new wiring harness. I just tried it and all I get is high beams. When I switch to low beams I get no light output. Any ideas from you guys that are running the RS HID's? Thanks in advance.
zZzDoc is offline
post #2 of 2 Old 07-15-2011, 05:45 AM
mor4wd's Avatar
Sorry, no help here. I installed mine and they just worked. Maybe RS will chime in.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
