tranny temps - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 16 Old 07-12-2011, 06:11 PM Thread Starter
twin200's Avatar
tranny temps
I know this has been brought up a couple times,but after a search with no results, I'm concerned with some tranny temps. I drove the truck 10 miles(empty)and was showing 196,ambiant temp was prolly 80 degrees.Isn't this a little high.I also recall towing 10,000 at a ambiant temp of around 95,tranny temp showed 196
2000 F-350 7.3 4wd cc,dually lariat
afe intake,programmer. rear airbags
2011 F350 6.7 cc,4wd shortbox lariat
Tinted windows Gray bedliner(diy)
Tool box Bull bar
Front aux lights Rear aux lights
Onboard air Train horns
Billet grille LED bed lights
Mike
twin200 is offline
post #2 of 16 Old 07-12-2011, 06:16 PM
sounds like a dummy gauge to me i'd install an aftermarket one...just saying..
Dietoremain is offline
post #3 of 16 Old 07-12-2011, 06:17 PM
I tow a 13k 5th wheel and I usually run around 205 to 210 loaded and in the 195 range unloaded. I also thought it was a little high, but I guess not
Be Safe
THE DAWG
DCFIREMANN is offline
post #4 of 16 Old 07-12-2011, 06:54 PM
mor4wd's Avatar
Isn't DieToRemain the same guy who called the coolant temp gauge a "dummy" gauge. I can tell you for a fact that it's not. It's a digital readout showing the exact temp. I've tested it with a temp gun.
Twin200
The tranny needs to be at about those temps in order to shift properly. You only need to worry about it if it goes over 220. That's when you start burning your fluid.
HeavyAssault likes this.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #5 of 16 Old 07-12-2011, 07:05 PM Thread Starter
twin200's Avatar
Twin200
Yeap, I,ve seen several guys talk about the 220 mark,compared to the7.3 these numbers I'm seeing are high.
Tool box Bull bar
Mike
twin200 is offline
post #6 of 16 Old 07-14-2011, 01:16 PM
Ren
Ren's Avatar
I posted this same question a few months ago on the tranny temps. Mine runs at 195 ish all the time. Thats on flat Florida land though, so far I havent hit any mountains yet. It stays the same temp pulling a 11k fifth wheel around 70 - 75 mph. But like I said, thats all flat land pulling, no mountains yet. Even in stop and go traffic it stays the same too.
Im guessing its all good.
2011 6.7L F350 DRW CrewCab
Our adventures,
Ren is offline
post #7 of 16 Old 07-14-2011, 02:02 PM
tjbrowder's Avatar
No issues with 196....I get the same with my F450 in 99 degree weather.
Asked my tech about this a week after I took delivery, he checked with Ford, all is good.
2011 F450 CC/LB 4X4
2010 F250 CC/SB FX4 *SOLD*
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website (Powerstroke.org or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my truck, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
tjbrowder is offline
post #8 of 16 Old 07-14-2011, 02:04 PM
It's a dummy gauge on 7.3s. LOL
That does seem hot, but maybe the new trannies just run a little hotter?
Austin G is offline
post #9 of 16 Old 07-17-2011, 01:35 PM
Quoted: 14 Post(s)
My tranny temps don't seem to change a lot in the moutains, but my oil temps do climb while I am climbing a grade. They will climb from 200 to 230 on a good 8% grade
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #10 of 16 Old 07-17-2011, 02:31 PM
Dave Nowlin's Avatar
I believe these trannies have synthetic fluid from the factory. Synthetic fluids will tolerate higher temps.
2011 F-250 Platinum White King Ranch FX4, Scan Guage II & Pullrite Super Glide Hitch
2006 Montana 3295 RK
Dave Nowlin is offline
