oil deep stick - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-09-2011, 05:11 PM Thread Starter
oil deep stick
Mine oil deep stick is hard to be read.Anybody have that problem and if yes what did you do?I just change the oil and I can't for sure where is the oil mark on the deep stick.
petei is offline
post #2 of 8 Old 07-09-2011, 05:26 PM
late_99_PSD's Avatar
Quoted: 10 Post(s)
Dipstick ?
Allen
1999.5 F-350 7.3, six-speed
late_99_PSD is offline
post #3 of 8 Old 07-09-2011, 05:49 PM
twin200's Avatar
HUH? Try better lighting,at least be between the high and low marks
2000 F-350 7.3 4wd cc,dually lariat
afe intake,programmer. rear airbags
2011 F350 6.7 cc,4wd shortbox lariat
Tinted windows Gray bedliner(diy)
Tool box Bull bar
Front aux lights Rear aux lights
Onboard air Train horns
Billet grille LED bed lights
Mike
twin200 is offline
post #4 of 8 Old 07-09-2011, 06:02 PM
Quoted: 10 Post(s)
Look at both the front and back side of the dipstick, make sure they are at the same level, the wipe off the face with the marks, then look at the back for referance to where the mark is.
Allen
post #5 of 8 Old 07-10-2011, 08:45 AM
CascadeF250's Avatar
You will find that it is much easier to read the dipstick first thing in the morning after it has sat overnight. One chance is all you get because once you pull the dipstick and try it again oil in the tube confuses the reading. Someone suggested pulling the dipstick up about 2 inches and waiting 10 seconds or so for the oil to drain off but that didn't help me. I cross hatched both sides of the dipstick and that made it easier. Remember the manual says to read either side of the dipstick and it is always higher on one side than the other.
CascadeF250 is offline
post #6 of 8 Old 07-10-2011, 05:24 PM
We have a Trans dip stick like this at work on one of the Log handler,the tube is real long and has a Bend in it,The Dip stick is around 6' No joke,the guys more often than not look at the wrong side,that being the side thats rubbing on the tube and get oil were it really isn't...
like said look at both sides of the dip stick and go with the low side,it will be the correct side...
far as seeing the oil on the stick it's self... Flat black paint will make a huge difference,and after a few oil changes the oil will not be clear even after just being changes....You never get 100% of the old Oil out ,unless you rebuild the motor LOL
the old oil will tint the new oil to a point you can see it...just put the correct amount in it and run the motor,maybe check it the next day after work....
Lead Foot is offline
post #7 of 8 Old 07-10-2011, 06:33 PM
First 6.7 PS Destroyer
mysticblu999's Avatar
Quoted: 2 Post(s)
Ford says to wait 20mins before you check the DEEP STICK
2011 F250 6.7 4x4 CC Lariat
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
5" MBRP straight pipe
AMP Steps
Truck pics ---->
mysticblu999 is offline
post #8 of 8 Old 07-11-2011, 06:19 PM
Mine is hard to read as well... I just "deep" it a few times to be sure!
LilRichard is offline
