Cleaning Exhaust filter - Ford Powerstroke Diesel Forum
post #1 of 23 Old 07-04-2011, 08:21 AM Thread Starter
We have had the truck for three weeks(and loving it) and have 1600miles on it. I have only had the "cleaning exhaust filter" message show up twice. The first time was at 746miles, the second was at 1490(744 miles after the first). I was thinking the filter would be cleaned out more often, is this a normal interval? Appox. 800miles was pulling a 6k camper, about 550 hwy unloaded, the rest city. I am not concerned about that interval as everything seems to be working fine. Just thought it would regen more often?
cruiserwy is offline
post #2 of 23 Old 07-04-2011, 07:02 PM
I would say you just missed the message it only stays on for 5 or so seconds. Mine regens about every 200 miles.
2011 F250 6.7 Lariat Ultimate FX4 CC Tuxedo Black Tan Bottom
stroke11 is offline
post #3 of 23 Old 07-04-2011, 07:10 PM
DEESLVRGN's Avatar
EXHAUST FILTER.....FOR REAL
2006 F350 CC LB SRW 4X4
-Goose Neck
-updated STC, Dummy Plugs, standpipes, oil feed line, "Blue" fuel pressure spring
-SCT Livewire TS w/Pyro "Looney Tuned"
-RECON smoked clearance lights, black OEM grill
-Kitty and Muffler delete
-POWERMAX TURBO
-58V FICM from QuickTricks
-Huge WISHLIST
DEESLVRGN is offline
post #4 of 23 Old 07-04-2011, 07:10 PM
DEESLVRGN's Avatar
how many more pieces of emissions crap are they gonna come out with????????????
-Goose Neck
-POWERMAX TURBO
-Huge WISHLIST
post #5 of 23 Old 07-04-2011, 09:38 PM
67powerstroke's Avatar
I regen about every 1000 miles. I track them with my gas cubby app. I've had 9 in the 10,000 miles I have on mine. I do feel they are becoming more frequent. My first two were 1500 miles apart.
Mine is a 250 4x4 cc sb...
2011 F250 6.7L
67powerstroke is offline
post #6 of 23 Old 07-05-2011, 04:53 AM
Dang I wish mine was like that, I wouldn't be so incline on deleting that crap. Wonder what makes one do it more than the other. I don't tow much and im about 50/50 hwy and city.
stroke11 is offline
post #7 of 23 Old 07-05-2011, 06:29 AM
I drive 85-90% hwy and hardly tow anything. I just haul construction tools and supplies in the bed. Trust me I still think DPF's are crap! I feel they cut the life span of the motor in half and waste a ton of fuel. They also cost an as$ load and need maintained costing more! My friend drives a Peterbuilt w/DPF and they say he should get 8mpg and he is getting 4mpg. That's just crazy if you ask me. 50%?!
2011 F250 6.7L
post #8 of 23 Old 07-05-2011, 06:30 AM
I say the ditch the DPF and leave the scr and doc and we would be good
2011 F250 6.7L
post #9 of 23 Old 07-06-2011, 06:49 PM Thread Starter
Found some info in the owners manual...page 55 of the diesel engine supplement, section reguarding passive regeneration. Says the filter can "self clean" if the exhaust temp is high enough to burn off "some" soot. Wondering if thats why some will go longer It is possible I didn't see the message pop up on the instrument cluster, but I thought I would have seen it a few more times than what I did. According to the manual it should regen about every 100-500 miles. Either way, totally happy with the truck so far
post #10 of 23 Old 07-06-2011, 06:59 PM
Zytek_Fan's Avatar
Quoted: 40 Post(s)
Towing = higher EGTs, so it would have the tendency to already burn out what's in there, and then unloaded highway doesn't produce much soot.
It's normal. If you start getting them ALL the time, then there is a problem.
****ing emissions equipment is costing millions, maybe even billions to be fixed, since they seem to break on a regular basis
Back to the blue oval: 08 F350 FX4 CCLB - DPF/EGR delete - Spartan tuner - S&B CAI - 4 in DP to 5 in SP
First truck: Early 99 F350 SC LB ZF6 4WD - SOLD
Zytek_Fan is offline
