What's with th crapy tow mileage? - Ford Powerstroke Diesel Forum
post #1 of 27 Old 07-03-2011, 07:40 AM Thread Starter
Hey guys. I made my first long tow trip with the "scorpion" and I'm a little disappointed. I have a 2011 cc sb king ranch with 3:55 rears and 20" rims. I tow a 35' 9000 lb travel trailer. I went from connecticut to Maryland. @ 350 miles. It should be known that I have a mp8 and a bully dog gt tuner, that was set on tow, the mp8 was turned up all the way. I got 10 mpg!! I have a aux fuel tank in the bed 50 gals. The chevy had a titan tank in it. I know there is some weight difference. But I think I should have kept the duramax I had. Last year same trip I got 11.8 mpg with a PPe standard tuner set on 2. The chevy was a 2009 LMM. What is going on? I get 16.5 not towing with the Ford which I like very much. The chevy was at 15.9 mpg not towing. So it's better not towing which is 90% of the driving I do. I have a bed cover also on the truck which I had on the chevy too. The ford has 6800 miles on it now. Should I be pissed or is this pretty much what I should expect?? Thanks for the input.
bfuelstroke11 is offline
post #2 of 27 Old 07-03-2011, 07:53 AM
7.3Lariat's Avatar
From the last issue of Diesel Mag that is about what they got too. So seems to be what to expect.
______________________________________________
Mike
SOLD
Mods: BD-X monitor, 6637, BTS, GT38R, Snow MPGMax, International up-pipes, Hi-Flow Outlet, 5" Diamondeye, HPx, FRx, Gearhead tunes, Tru-Cool tranny cooler, Remote Start
376HP 791ft-lbs on 10.15.11
7.3Lariat is offline
post #3 of 27 Old 07-03-2011, 08:26 AM
richc22a's Avatar
With mods? Recommend a tow w/o the mods and check. I pull a 16k f'ver and depending on the weight of my right foot get 9-12 w/o trouble. Was the trip rolling hills, or???
I would back out the mods on the next 'bunny hop' and check the mpg just because...it is the 'first generation' of mods, a little more 'fine' tuning may be ahead.
Or....slow down 5 mph, that seems to make the biggest difference...
35 gallons @ 10 mpg
29.66 gallons @ 11.8 mpg
__________
4.34 gallons @ 4.00 per gallon = $17.36 extra expense... each way.
"But I think I should have kept the duramax I had. " For $34.72, I would keep the amenities, the looks, the class, and not whine over $34.72 which makes you look... cheesy, tight, not fitting with driving a high dollar mac daddy truck...
Driving: 2011 Pale Adobe...F-350 CC 6.7 FX4 3:55-Locking Rear End-Dual Alternators-premium Lariat, moon rf, added wheel flares, 2-tone black base
Picked up 4/29/10 as of 06/20/2012 109,000+miles
richc22a is offline
post #4 of 27 Old 07-03-2011, 09:35 AM
ups 6.0's Avatar
Originally Posted by richc22a View Post
__________
LMAO
Heck I wouldn't have kept the Durapad even for $100 more....anyhow,bone stock @25,000 mi towing 11,000 lbs 28ft/5fer gets 13.1 mpg
Check the air pressure in your tires as well and go easy on the right foot
2011 F350 Lariat,6.7,3.55, crew cab, FX4, longbed w/custom Reese 5th wheel hitch,white,black leather,moon roof,navigation.
ups 6.0 is offline
post #5 of 27 Old 07-03-2011, 03:15 PM Thread Starter
Thanks
Thanks for the replys. I will try it stock on the way home in 2 weeks. I do love the new truck and all the bells it has over my chevy. Also it rides better,has more room for the kids too. My wife doesn't like it as much as the chevy though . But she also doesn't drive it much. But when she did last week she said "dam it goes good".anyway thanks for the info I will post again when I get home after the trip..
post #6 of 27 Old 07-03-2011, 06:18 PM
4x4ord's Avatar
Quoted: 3 Post(s)
I've got a 2010 GMC and a 2011 King Ranch. Fuel economy, performance and handling go to the GM. Comfort, quality of material and in cab features goes to Ford.
4x4ord is offline
post #7 of 27 Old 07-03-2011, 08:11 PM
Dave Nowlin's Avatar
There is a bit of comfusion regarding these trucks. The inflation pressure shown on the door post is 65# for the trucks with the 20 inch Michellins. If you call Michellin and talk with them they will recommend 80# when towing that much weight. The tires will run cooler and fuel economy will increase over running 65#. Not saying for sure that is the case here but some have towed pretty heavy with these trucks running 65#.
Dave Nowlin is offline
post #8 of 27 Old 07-03-2011, 08:21 PM
Thats Good stuff Dave!
Also Note that you should Adjust the air pressure when the tires are cold,when possible..
Lead Foot is offline
post #9 of 27 Old 07-04-2011, 12:17 PM Thread Starter
Tire pressure
Hey guys. I wanted to tell you when on that trip towing,before I left I adjusted the air pressure to 70 psi all around. If figured that it would expand to about 75 while driving that far. So I think the air pressure is not the issue. I'm going to try putting it back to stock on my way home. That sucks though not as much extra power when hitting the hills. I think I will slow down about 5 mph as I was doing 70 mostly all the way to Maryland. With it back to stock and the 5 mph decrease I'll see how that is.
post #10 of 27 Old 07-04-2011, 03:15 PM
Michellin would tell you to run 80# all the way around for best towing capacity (axle rating), handling & fuel economy. That means 80# cold inflation pressure. If you run lower pressure you will shorten the tire lfe. These tires aren't cheap. You will also find if you will stay at 65 or below it will work wonders with your fuel economy. Another thing to consider is your trailer tires. If they are true trailer like those that come from the factory and you check the sidewalls, you will see that they are only rated for 65 m.p.h. Driving 70 and hot pavement can lead to disaster. Tires go boom!!!
