suspension sag while towing - Ford Powerstroke Diesel Forum
post #1 of 17 Old 06-17-2011, 11:43 AM Thread Starter
Smile suspension sag while towing
I have a 2011 F 250 king ranch that I tow a 9000 lb travel trailer with,I got the trailer last year towed it with my 2009 chevy 2500 duramax with no noticeable sag in the rear at all.I got this truck in the winter and did'nt tow with it until the other day, then noticed how soft the rear is compaired to the chevy.Does anybody know about f350 rear suspension blocks being put into a f250 to have less sag while towing? Or is there something else i can do?I do have a weight distribution hitch with anti sway.I adjusted it preety good, but i'm still not that happy.What should i do? I also only tow about 8 times a year,so is it worth all the trouble? Thanks for the info.
bfuelstroke11 is offline
post #2 of 17 Old 06-17-2011, 12:03 PM
Dont Mess With Texas!
ThirdCoastStroker's Avatar
Quoted: 14 Post(s)
get airbags
Casey
New Truck
15' F-350 King Ranch 4x4 CCLB
Platinum White / Caribou Metallic
Stock for now!
Old Truck
08' F-350 King Ranch 4x4 CCSB
H&S Mini Maxx 300 HD
5" Straight Pipe to 7" rolled tip
AFE S2 PDS
ARP Head Studs
FloPro EGR Delete with Intake Elbow
FloPro CAC pipe
Rebuilt beefed up OEM Up pipes
Deisel Site Coolant Filter
Firestone RideRite Airbags
Leveled
35X12.50R20 ProComp Xtreme A/T
Ranch Hand Front and Rear Replacement Bumpers
ThirdCoastStroker is offline
post #3 of 17 Old 06-17-2011, 12:26 PM
ups 6.0's Avatar
Got pics??
2011 F350 Lariat,6.7,3.55, crew cab, FX4, longbed w/custom Reese 5th wheel hitch,white,black leather,moon roof,navigation.
ups 6.0 is offline
post #4 of 17 Old 06-18-2011, 06:45 AM
Airbags Airbags Airbags.. With wireless compressor.. The apparently softened up the rear springs to improve the ride. I have a toy hauler TT and had the same sag.
ID:	26327   Click image for larger version
ID:	26328   Click image for larger version
frt2599 is offline
post #5 of 17 Old 06-18-2011, 07:22 AM
What are the wheel well measurements at each wheel unloaded vs. when you are loaded with the TT packed-up and trailer connected on flat ground?
RedRocket204 is offline
post #6 of 17 Old 06-18-2011, 07:38 AM
4x4ord's Avatar
Quoted: 3 Post(s)
I would start with the F350 blocks. The 350's start out with the back up a little and then would level out when you tow. The 250 to 350 blocks are interchangeable just need longer u-bolts.
4x4ord is offline
post #7 of 17 Old 06-27-2011, 01:09 PM
Great Pix! Thanks!!!
2011 F250 XLT 6.7 PSD 4X4 Crew 3.31 rear-end in Sterling Grey
1tough_crew is offline
post #8 of 17 Old 06-27-2011, 07:34 PM
richc22a's Avatar
My 07, and 09 F-250's would sag slightly with my 8k bumper pull. Which is precisely why I spent the additional $600.00 and got the F-350 srw. On the F-250's the equalizer hitch helped, evening everything out, reduced the night 'bright lights' in the face from drivers not enjoying my headlights in their face. The last time I pulled the bumper pull w the F-350, no equalizer hitch, no sag, ride not noticeably different than the F-250.
Almost all the rec veh tow accidents I see are with vehicles overloaded at the bumper, explorers, 1/2 ton's... to me the sag is a warning.
Driving: 2011 Pale Adobe...F-350 CC 6.7 FX4 3:55-Locking Rear End-Dual Alternators-premium Lariat, moon rf, added wheel flares, 2-tone black base
Picked up 4/29/10 as of 06/20/2012 109,000+miles
richc22a is offline
post #9 of 17 Old 06-28-2011, 11:56 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Air bags or Deaver rear mini spring packs..
CT Performance, Inc. is offline
post #10 of 17 Old 07-02-2011, 03:43 PM
Sag/Camper Package?
Reading about sag issues made me wonder, so I ordered my '11 with the camper package, ensuring I got the heaviest suspesion, sway bar, and a single overload leaf in the rear. I have a 25" low profile 5th wheel with gooseneck adapter, and the factory goose neck hitch package. The trailer weighs 6k plus, the local Montana DOT scale says my front axle weight driver off, full fuel is 4680,rear axle 3340. 8020 total, 10k gvw package My 97 didn't weigh this much. Both Super cab long box, diesel. My trailer is lighter than most I see in the posts.With hitch weight, 2 dogs, 2 passengers, I estimate I will be at max GVW, but under both max GCVW, and rear axle weight. Does anyone have experience with the camper package and sag? Thanks, Pete
colstripguy is offline
