F250 2011 USB IPOD - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-15-2011, 10:24 AM Thread Starter
F250 2011 USB IPOD
I want to put my IPOD in my glove box of my truck, so I dont have cables running through my truck. anyone have any ideas how to get a USB cable inside the glove box
rodand is offline
post #2 of 10 Old 06-15-2011, 10:41 AM
See this thread:
http://www.powerstroke.org/forum/6-7...-usb-port.html
It mentions getting a cable from ford I just got a normal cable USB mini B to standard Ac able to and a female to female standard A from Fry's. Plugged it in, made sure that it recognized the device on the USB2 port, and then cable tied it to the preexisting USB cable so that it wouldn't work it's way out.
Total time: 5 minutes
Note. Take a look at that original cable as I'm going off memory that its a USB mini B.
Once you get every thing hooked up, from media button you should then have USB2 in addition to USB. You can also select it via voice by saying "USB 2"
zonedar is offline
post #3 of 10 Old 06-15-2011, 11:02 AM
I also did a full write up with part numbers on how the add a secondary USB port with a face plate for a more professional look to the center console.
Secondary USB in Armrest Center Console
RedRocket204 is offline
post #4 of 10 Old 06-15-2011, 11:07 AM
doczenith1's Avatar
Quoted: 7 Post(s)
You only have usb1 or usb2 available, not both as I recently discovered when I tried to plug in a second usb flash drive. The system would only recognize one usb port at a time.
Al Bedford, P.E.
2011 F350 Lariat, SC, SWB, 6.7L, 4x4, 3.55ELD, FX4, Lariat Int Pkg, 20's - Ordered 10/27/2010; Delivered 12/13/2010
2002 F250 Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. 12/2001 - 12/2010 - SOLD
With spreadsheet open click File then Download if you would like a copy of the spreadsheet.
doczenith1 is offline
post #5 of 10 Old 06-15-2011, 11:41 AM
I have a stick in my glove box with tunes on it and my Iphone plugged into the dash outlet. If I say "USB" it switches to the Iphone and if I say 'USB2" it switches to the stick.
Tastes Great. Lasts a long time...
zonedar is offline
post #6 of 10 Old 06-15-2011, 12:05 PM
doczenith1's Avatar
Quoted: 7 Post(s)
Interesting. I only tried to switch via the radio controls. I'll try with the voice recognition.
On Edit: Sure as sh!t that worked!
Al Bedford, P.E.
post #7 of 10 Old 06-15-2011, 12:17 PM
zonedar is offline
post #8 of 10 Old 06-22-2011, 01:28 PM Thread Starter
Thanks for everyones help. I went Ford and bought the USB cable. I couldnt get it to fix in the usb port. So filed it down a little and now it fits great. Right when i plugged in my IPOD, my stereo saw USB2. Works great, took less than 10 minutes..thanks again
rodand is offline
post #9 of 10 Old 07-08-2011, 01:42 PM
shook08's Avatar
2nd USB
Went to Ford bought usb cable and installed it, will not recognize my Iphone at all, will charge my second gen 32gig Ipod, but nothing else just charging. any thoughts?
2011 F350
shook08 is offline
post #10 of 10 Old 07-08-2011, 04:40 PM
2011 F350
Have you tested your new Ford cable using other equipment, like a PC and camera and not just using the SYNC module? The Ford cable is just a standard Mini-USB cable with a female end instead of male on the non-mini side.
