Emission equipment - Ford Powerstroke Diesel Forum
post #1 of 14 Old 06-02-2011, 02:15 PM Thread Starter
Emission equipment
My dad plans on buying a 6.7 but since def freezes around 12 degrees he is concerned. Obviously the tank isnt going to explode but how long will it take for it to thaw out? That would be a burden if you fire it up and try to go only to be in limb mode because the def is frozen. Also a cat on a diesel is considered a dpf correct? And this truck still has an egr right? To much stupid ****
jordan572 is offline
post #2 of 14 Old 06-02-2011, 02:18 PM
No a cat is not a DPF.
Diesel Exhaust Fluid is subject to freezing at the lowest temperatures. For example, Diesel Exhaust Fluid (made up of a 32.5% urea solution) may freeze at temperatures at or below 12 F. Although this temperature is encountered in colder climates during the winter season, it has not proven to be a problem for SCR-equipped trucks. Freezing does not impact its functionality and Diesel Exhaust Fluid is easily thawed within moments by the warmth of the engine.
Some automotive-grade urea producers are working on non-freezing additives and technologies. In the meantime, equipment systems are being developed and will be used to ensure that Diesel Exhaust Fluid thaws quickly. In fact, the EPA sees no problem in allowing it to reheat in the morning using the warmth of the engine when the truck is started.
While freezing may be touted as one of the bigger concerns with SCR technology, there have been no problems with freezing based on winter reliability and growth tests across Canada and North America. Furthermore, freezing has not been an issue among Northern European fleets in countries like Norway.
Austin G is offline
post #3 of 14 Old 06-02-2011, 02:25 PM Thread Starter
So does the 6.7 have a cat and a dpf? After reading about the urea system and stuff it says that the urea is injected in mixing with the nox then all of it runs through a cat where separation occurs and ammonia and water come out the other side. Does this then run through a dpf?
post #4 of 14 Old 06-02-2011, 07:11 PM
the system is quite the mess if you ask me, i say DELETE DELETE DELETE and enjoy a real diesel
Dietoremain is offline
post #5 of 14 Old 06-03-2011, 03:29 AM
matty21's Avatar
they have it all, cat dpf def muffler , all of it. but no it wont freeze theres a tank heater
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #6 of 14 Old 06-03-2011, 09:36 AM
In my area we get to -30 periodically during the winter. I have never had any problem with the DEF freezing in my 2011 F350. I plug in the truck at night, but not all of the time. The new 6.7's handle the cold much better than my 2002 7.3 did. I would not remove the emmissions stuff unless you want to risk voiding the warranty on a very expensive engine.
mrock is offline
post #7 of 14 Old 06-03-2011, 02:42 PM
DEF tank has 4 heaters and it also has 4 line heaters. Don't worry about the cold.
Current Rig: 2011 F-350 CCSB Lariat chrome FX4 Tuxedo Black.
Mods: aFe stage II, 8000k HID. 6" 4link Skyjacker Lift, 37" Toyos Wrapped around 20x9 XD MisFit Rims, H&S Minimaxx, 5" FloPro straight pipe
Traded: 2006 F-350 CCSB Amarillo Edition
Mods: 6" BDS 4-Link Lift Kit, 4" MBRP Cool Duals Exhaust, AFE Intake, Edge CTS Evo, 37x13.5x20 Toyo MT wrapped around XD Spy 20x9 Rims
UA Local 488 Steamfitter/Pipefitter
AlbertaStroker is offline
post #8 of 14 Old 06-04-2011, 03:42 PM Thread Starter
Ok cool. Will the def tank still heat up when the truck isn't plugged in? If it sat to long in the cold heating the tank i would think the batteries would die. Usually my dad doesn't plug it in because 95% of the time it is in a heated garage.
post #9 of 14 Old 06-04-2011, 04:01 PM
it won't heat if the truck isn't running.
Austin G is offline
post #10 of 14 Old 06-04-2011, 07:45 PM Thread Starter
Ok then back to my main question. How long does the truck have to sit and run before the urea tank thaws enough to provide full power? Just to clarify, the urea tank heats while it is running and plugged in?
